Question about Panasonic Lands Phones
Kx-tga401 call block
Call block is full. I want to edit so new numbers can be blocked.
cnavarro
  • 2460 Answers
SOURCE: Block international call
In the manual, there's a section on Toll Restriction (TRS). It's not something that is easily explained in a public or any forum.
I did attempt it once, and this happens to apply to a TA-824 which you may or may not have. Anyway, here's a link to that forum and thread http://members4.boardhost.com/ablecomm/msg/1201934621.html
Carl
Posted on Sep 04, 2008
SOURCE: kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Posted on Feb 28, 2010
  • 8 Answers
SOURCE: how to vlock number
go back to your phone operater or ring BT
Posted on May 30, 2010
cnavarro
  • 2460 Answers
SOURCE: Dear Sir, I am using KX-TEM824 PABX system and
That doesn't explain so well in a free forum. Try the features manual under TRS (toll restriction). COS (Class of Service) and Verified Toll calling. With restrictions, you set up a numbering plan that will bar mobile calls, then either verify and override, or alow only certain phones the ability to dial outside calls to those numbers. If you absolutely have to allow access to certain mobiles, you can add them to the Speed Dial tables where the call can be allowed by the fact it's in a speed call table.
It will take you 30-60 minutes to read and set up the programming.
Carl
Posted on Dec 23, 2010
SOURCE: Hi there, I have a Panasonic kx-tga840c cordless
Go to the main menu. Then click on the wrench Icon (initial setting). then go to call block. From that list you can remove the blocked number.
Posted on Feb 11, 2011
I need to know how to unblock a telephone number on my model #KXTGD220 telephone
Here is a link to the owners manual page for call blocking. It has a lot of abbreviations I don't understand, but hopefully they will match what you see on your menu and display.
https://www.manualslib.com/manual/888692/Panasonic-Kx-Tgd210.html?page=26#manual
Jun 01, 2016 | Clothing
How do I unblock a phone number
You can find the procedure in the programming section of the manual. Look for "Viewing/editing/erasing call block numbers" The Panasonic KX-TGEA20 model number crosses to the additional handsets for your cordless phone, but these handsets are compatible with the TGEA-21X through the -27X series base units. If the [MENU] # code sequence is different you will have to share your exact model number.
The Quick -n- Dir(ect) answer is:
    1.[MENU] #-2-1-7
    2.<Navigator key "up/down" arrows> to "Block a single number" ? [SELECT]
    3.<Navigator key up/down arrows> to highlight/select the desired entry.
    This should offer you the choice to edit or erase, so choose...
    4.[ERASE] ? <Navigator key up/down arrow> to "Yes" to confirm your action? [SELECT]? [OFF] The number should no longer be on the "Blocked" list if you go back in and start from step 1 (above).
    If you have lost your original manual you can get a replacement from the Panasonic FTP site here:
    ftp://ftp.panasonic.com/telephone/om/kx-tge210_mul_om.pdf
    V/R,
    Veg
    If a train station is where the train stops, what happens at my workstation?
    ~Author Unknown
May 05, 2016 | Asavings Panasonic KX-TGEA20S Dect 6.0 1...
I have a Panasonic digital cordless phone model KX-TGE210. I accidentally block a number on my phone that I need to unblock to receive calls. Can you tell me how to unblock a number?
I have similar phone.
Press Menu then enter #217 to edit blocked numbers.
Use up or down arrow to scroll through numbers.
You can erase or edit blocked numbers.
For more info, see manual at: http://www.manualslib.com/manual/754430/Panasonic-Kx-Tge210.html?page=1
Mar 08, 2016 | Panasonic Lands Phones
Additional handsets installation manual for panasonic kx-tga401
The KX-TGA401 handset can be located in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTGA401-INSTALL.PDF
May 26, 2014 | Panasonic Lands Phones
CHANGE GREETING ON MODEL KXTGA401
The KX-TGA401 is the handset. The greeting is controlled by the answering machine. What model answering machine do you have on your phone line?
Oct 03, 2013 | Panasonic KXTGA401B KX-TGA401B KX TGA401B...
I blocked calls on my panasonic KX-TGA652 and now want to unblock or delete them because it is full and I don't see how to do it
Go to Menu-Initial settings click Select button. scroll to Call Block hit Select ,then Scroll for numbers you want to Unblock..
Oct 29, 2010 | Lands Phones
Kx-TGA641T how does one unblock blocked number
numbers
you can also edit:
■ Editing a number:
Sep 28, 2009 | Panasonic Lands Phones
I can not remove call block from my phone. model kx-tg6414
I had a similar problem with a KX-TG6445. To edit the call block list from the handset press Menu then # 2 1 7. This will take you to the call block menu where you can edit or erase the blocked numbers list.
Sep 21, 2009 | Panasonic KX-TGA101S Cordless Handset
Lands Phones Logo
1,118 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
