Question about Ricoh Aficio 450 Copier
Ricoh Afficio 250 SC900 Code Reply
I replaced the top original paper feed that goes over the glass...I plugged it into the machine inadvertantly while it was on...then the code SC900 popped up. I checked fuses and fuse #5 was blown, I replaced it and the new one immediately blew. I am not sure if it is the nvram, or the entire OICSS Board. If I change the board would it come with a new nvram? or could there be another problem that triggers the code and blows this fuse.
Thank You,
REv. Scott Gallagher
PS Our church really does not have the funds to buy a new copier so any help is greatly appreciated.
  • 162 Answers
If he does not have another power supply, I would suggest I begin to disconnect boards and parts one by one until the fuse stop jump. The problem can be anywhere.
Fuse 5 makes work the peripheral.
Disconnect to finisher ADF if it has them.
Posted on Sep 14, 2009
  • Ricoh Master
  • 2,794 Answers
The problem is getting parts for 220s and 250s is tough. I'm running out of sources myself. Do you have any way of checking the power supply?
Posted on Jan 05, 2009
My Ricoh afficio say clear misfeed but I cleared it but message always kept coming when it try to copy
if you are not seeing paper when it jams then most likely is in tray area could be anything from cassette rails or stop out of place, feed tire slipping or bad clutch. will need a tech to see what it is
May 31, 2017 | Ricoh Office Equipment & Supplies
How do i fix error code 452 in Ricoh Afficio MPC2030
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
Jan 29, 2016 | Ricoh Office Equipment & Supplies
Ricoh Aficio 250 sc900 help
need replace the PCU unit as drum is damage and leaking the charge
Apr 20, 2014 | Ricoh Office Equipment & Supplies
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
Hi . my copier is aficio 700 .The error is sc 900 .that relate to electical counter .I Check the connection between the NVRAM and controller. Replace the NVRAM. Replace the controller. but the error not...
Other possibilities
A095/A096/A097
SC 900
[SC900] - replace fuse 8 0 4, DC power supply
A109/A172/A199
SC 900
[SC900] - replace black total counter
A133/A195/A217
SC 900
[SC900] - CN4 0 3 SCU PCB, poor connection
A133/A195/A217
SC 900
[SC900] - replace SCU PCB, see FSM page 5 64 for rom and dip switch info
A193/A224/A264
SC 900
Total counter error: Fuse #5 on PSU blown
A193/A224/A264
SC 900
Total counter error: Total counter defective
A229
SC 900
[SC900] - NV ram defective
A230/A231/A232
SC 900
[SC900] - re load copier firmware
A246/A247/A248
SC 900
[SC900] - replace counter harness
A292/A293/B098
SC 900
Electrical counter fail - Replace Mechanical Counter
A292/A293/B098
SC 900
Electronic counter error - Replace NVRAM-B098 9590.
A292/A293/B098
SC 900
[SC900] - replace IOB PCB
A294/A295
SC 900
[SC900] - NVRAM defective
B010/B188
SC 900
Electrical total counter error - NVRAM data defective
Jan 28, 2011 | Ricoh Aficio 450 Copier
Lanier 5235 sc900-01
Hello sir; You may try to reset the machine follow the steps; Press "clear mode" "107" and hold down "clear/stop" key for 3 seconds, turn power off and back on .
Sep 19, 2009 | Ricoh Aficio 1035 Copier
Fixed one problem now another on Aficio 250
Sounds like you may have missed a connection on the powersup unit that controls the paper feed board. No paper from trays= late jam detection @ A and or B!!!!
Jan 16, 2009 | Ricoh Aficio 450 Copier
Afficio 250 SC900...copier will not operate
Is the SC just 900 or is it SC900-01? If it is 900 then it is a total counter error stating that the machine exceeded 9,999,999 copies. If the machine does not have this many copies then the NVRAM is defective. If the SC is 900-01 then the total counter is not working properly. Causes could be .... the mechanical total counter defective, mechanical total counter disconnected, or a poor connection at the total counter. Hope that it is the latter of the 2 codes.
Jan 03, 2009 | Office Equipment & Supplies
Ricoh Afficio 250 code SC900
If changing the total counter the fault does not disappear, try pressing . (point) and # for more than 10 seconds. this reset and reload the software.
Jan 03, 2009 | Ricoh Aficio 450 Copier
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
169 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
