Question about Goodman CACF048B2A Air Conditioner
6 led lights flashing - Goodman CACF048B2A Air Conditioner
Gu10 led light bulb are energy saving led Bulbs
Yes Gu10 led bulbs are energy saving led bulbs please check out the link below to know more about how much Gu10 led bulbs save energy
SHEERLED LED Bulbs SPOTLIGHT IN UK GU10 LED Lights IN UK
Sep 08, 2015 | brianydeal 3w Gu10 16 Color Rgb Led Light...
Blue light does not flashes
The LED will only flash when the system is armed. Are the remote controls for the system working. The parking lights should flash when activated.
Jul 18, 2012 | Vehicle Parts & Accessories
Rapidly flashing turn signal continues even after I replace bulb
And all lights flash? Is this with or without a trailer and its lights connected? LED lights installed?
Many times when there is a slow or fast rate that the signals flash its due to a chaneg in current being drawn. Either from hooking up trailer lights or changing the bulbs to LED. LEDs will draw less currenct and more lights more current.
There are electronic flashers that automaticaly adjust for different current draws to make the lights flash at a normal rate and they plug right in to replace your stock mechanical flasher.
Aug 30, 2011 | 2002 Chevrolet TrailBlazer
My android light keeps flashing (led light)
The flashing led light is part of most android phones. Different colors are associated with different apps. The flashing light is used to give a notification to the user. You should be able to go within the app settings and choose to turn off the flashing led light for specific apps. Hope this helps.
Apr 22, 2011 | HTC Desire Cell Phone
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
One flashing red light on xbox360 ( not red ring)
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
Once you get this code, go to: http://forums.xbox-scene.com/index.php?showtopic=484726
To get the reason for the code.
Sep 15, 2009 | Microsoft Xbox 360 Console
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Goodman CACF048B2A Air Conditioner Logo
19 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
