Question about Panasonic SDR-S26 Flash Media Camcorder
Get new flex cable with microphones for sdr26 panasonic
Cam got wet (fell into sink), took apart, dried and repowered. video/other functions ok, but must have torn the microphone flex cable on disassembly! any sources?
2 Suggested Answers
techman
  • 3130 Answers
SOURCE: Built-in microphone does seem to work
The only way to really tell if the buit in mic. is bad is to replace the mic or plug another one in the external mic. jack. Also use the input (red and white) RCA jacks and input a signal from a stereo or TV into it and record. If still no sound then its probably Bad capacitors in the sound processor Printed Circuit board. Sorry to be the bearer of bad news but mostly all of older camcorders suffer from this breakdown fault. Good luck
Posted on May 22, 2006
So what happened was that i was walking outside and my phone came out of my sweeter on to the floorbut the ground wasnt dirty or wet. (the phone had already fell once that day) i picked it up and looked at...
take it apart and check your flex cable connection, see you tube video for taking your phone apart, easy fix if you have a small screwdriver. Takes about 15 minutes.
Nov 07, 2010 | LG VX5500 Cell Phone
Just changed battery in nuvi 660 and now I have a very poor display. Like a computer screen with no video driver. Every thing was put back exactly as taken apart. Could it be the new battery?
No, one of the LCD flex cables is not fully inserted into its connector. unlatch the lock down flaps and reinsert the flex cables back in and lock down the flaps. Most likely this is a problem with the larger flex cable. If the screen lights, the smaller flex cable is OK. Its located to the right of the larger one in the center. The flex on the left is for the touchscreen.
- Jim
www.sharcnet-usa.com
Jul 04, 2010 | Garmin Nuvi 660 GPS Receiver
Bissell 7920. Took it apart how do i align the solution valve
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggds
Nov 23, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Can i use this camera as a Web Cam like some other cameras?
step 1 Check the manual of your digital camera to see if it can be used as a webcam. Many digital cameras have this functionality and even come with webcam software. If your camera didn't come with webcam software, use a third party web cam application such as SarmSoft WebCam. Find SarmSoft WebCam at ShareUp.com.
Step 2 Plug your digital camera's power adapter into the camera. Some won't function as a webcam unless they are plugged into A/C power. Even if your digital camera functions as a webcam while on batteries, A/C power saves your batteries and prevents your camera from shutting off in the middle of a broadcast.
Step 3 Connect a video cable into your digital camera's video "out" port. Your camera likely came with a cable made for connecting it to a to a video source. Plug the other end of the video cable into your video card's video "in" port.
Step 4 Set up your camera as close to your monitor as possible. This allows better face to face communication.
Step 5 Position yourself about 2 to 3 feet away from your digital camera. Most digital camera's focus best at this distance when used as a webcam.
Step 6 Use a separate microphone if your digital camera doesn't transmit sound when used as a webcam. Plug the microphone into the microphone jack of your sound card
Jun 25, 2009 | Olympus Stylus 600 Digital Camera
I was washing dishes in a full sink and it fell in now it reseted my ds and i cant see the screens
Ouch getting electronics wet is a bad thing If you dont have the tool to take it apart you can try shaking it to shake the water out If you can take it apart get some circut cleaner and spray the board lightly Its gonna have to dry out once it does it should work again
Jun 13, 2009 | Nintendo DS Lite Console
Dropped phone in water
SIM is probably bad or a little wet. but wait and let everything dry out and see if it works. Mine was soaked and the next morning worked fine. at least you probably won't have to buy a new phone.
Apr 28, 2009 | Samsung SGH-t229 Cellular Phone
Sidekick 2008 got wet
I dropped a phone in the toilet once, a T-mobile phone. it took a couple of days for it to dry out completely. Then I snapped it back together, and it was fine. Being that yours just got wet, and not immersed is different though, so you may want to take it into T-mobile and see if they can check it out for you because then you will know for sure what is going on. Good luck.
Jan 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Cordless phone fell in water, can it be fixed
Normally after drying out, It should work, If its not tho, you will prob be better off replacing it... If you have a nice one, With built in Answering machine and all that, check to see if its expandable, If so then just buy a expandable headset as a replacement, That way you keep the same phone system, get a new phone, and it works as good if not better than your old one.
Nov 24, 2008 | Uniden Cordless Phone
My Rainbow stopped running
I took my unit apart to clean it. I was careful to put it back the same way. Now it won't start.
Jul 07, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Panasonic SDR-S26 Flash Media Camcorder Logo
44 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
