Question about Remington Garden
My remington electric chainsaw 3.0 is not cutting and making a high pitch screech when i go to cut with it
When i was going to cut with it after my father used it it just sits on the tree and macks a high picth screech and the chain does not move please any info will help
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Hello. Please make sure the saw brake is not set. This locks the blade so it cannot spin. If it is locked then if you try to rev the saw, the blade cannot turn and the clutch will scream. The other thing it could be is it sounds like the chain is out of the groove and the clutch is slipping BAD. UNPLUG the chainsaw. Check to make sure the chain turns freely around the cutter bar. If it does not move at all, you will need to closely examine the cutter bar to see if it has 'popped' out of the guide path. You must also make sure the chain is on the drive gear correctly.
These are 2 things to look at that can help you. Hope this helps..
Posted on Nov 04, 2012
2 Suggested Answers
  • 4088 Answers
SOURCE: Electric Chainsaw - chain stops when you try to cut!
Remove the bar and chain--check the sprocket and shaft for any mechanical damage. Try to turn the sprocket by hand in a CCW direction, does the shaft move with it? Does it seem to turn the motor? If the sprocket and shaft seem ok, then you may have a damaged gear (likely plastic) within the gearbox. Hope this helps!
Posted on Jul 09, 2010
Remington manuals
For an electric saw, just add oil to the chain oiler, plug it in, and cut away. Do not put any body parts in contact with any of the moving parts of the saw.
Sep 02, 2014 | Remington 10" Electric Pole Saw Chain...
Electric chain saw pole wouldn't cut branches
Check to make sure the blade is not installed backwards. It's an easy mistake to make, everything will work OK, but the saw won't cut if the blade is on backwards.
Mar 15, 2012 | Remington Electric Chain Saw
Saw works but stops when I begin cutting a limb. Model # 104316-04 Thank you in advance. Joe Alcamo
Hi, make sure the chain is not on too tight, It should lift from the bar about a quarter inch. Also if there is a chain brake make sure that it is disengaged. If the chain stops but the saw is revving high then there may be a worn out clutch that needs to be replaced. Finally make sure the limb that you are cutting is not binding the chain under its' own weight.
Nov 16, 2010 | Remington Electric Pole Saw
I need to know the chain size for my Remington 14" electric chainsaw, Model EL-1
50 drive links; 3/8 pitch; and 0.050 gauge if an original 14" bar your, choose your chain here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Input "Remington; EL-1; 14"; All; All; All"
The one installed is probably green (low chance of kickback), all of them will work provided it is the original bar.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Remington Electric Chain Saw
My chain saw quit after the last cut.
buy a new saw this is a throw away society we live in oh yeah go green
Apr 05, 2010 | Remington Electric Chain Saw
Have a Remington electric pole saw blade stops when you apply pressure to cut
The drive sproket is stripped out. The small plastic gears inside the sproket are worn out causing your problem.You can order part 107713-01 from 1-800-654-8534
Oct 05, 2009 | Remington Electric Pole Saw
Need a bar for a 10ich Remington pole saw
www.masterparts.net/remingtonelectricchainsaw. USE THIS SITE AND FIND YOUR CHAIN SAW MODLE YOUR BAR IS IN THERE. I BOUGHT A REMINGTON ELECTRIC SAW 2 YEARS AGE AND THE THING CUTS BETTER THEN MY GAS SAWS, LOVE THAT THING
Aug 10, 2009 | Remington Electric Chain Saw
Remington 14 inch electric chainsaw replacement blades
You can 14SC available online at www.masterparts.net you also can contact them toll free at 800-446-1446. They ship parts out very fast.
May 25, 2009 | Desa International Remington 14" Electric...
Chain comess off bar ever7ytime u cut
put the chain on and adjust the chain tension so that it is a little snugger than it has been. that should solve your problem. if it doesn't it may be time to replace the chain bar.
Jan 29, 2009 | Remington Electric Chain Saw
Garden Logo
76 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
