Question about Hitachi 60SDX88B 60" Rear Projection Television
How do i connect my hitachi 60ux 54b to a cable outlet
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
The set will have at least one or more coax inputs (a and b) or with a cable box that has the video and audio output jacks on the rear to the same on the set but input---select that input on set for use.
Posted on Nov 05, 2012
Is it ok to use the power cord from my monitor to power my hitachi 42 hds 69 tv
if the connections are the same as would be the correct voltage ===yes
a power cord is just a power cord and carries electricity regardless of the voltage
however if the connection at the power outlet in the wall is different then that suggest that the cable in questions is connecting different voltages to the unit than is allowed
Sep 08, 2017 | Hitachi Televison & Video
WHY MY 2008 ROKETA 250CC MC-68A IS NOT GETTING NO SPARK, I HAVE CHANGE STATOR, IGITION SWITCH, CDI BOX, BUT NOTHING. HELP
Hi, Donald and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Roketa 250cc MC54 no Spark SCOOTER PROFESSOR
Honda Ch 250 Your service information center
http://roketapartsdept.com/
http://www.scooterdynasty.com/manuals/MC-54B-250%20User's%20Manual.pdf
Oct 16, 2016 | Roketa 50 Scooters
External hard drive not accessible
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 08, 2013 | Hitachi Travelstar 7K60 (DK23FA60) Hard...
Hitachi cp306 no power - checked outlet and power cable un- plugged and plugged back in. No power light
check the obvious things like lamp cover on properly, and air filter cover on.
what led up to this happening
May 16, 2011 | Hitachi Office Equipment & Supplies
Just got a hitachi 42hdt50m model plasma and cant figure out how to hook up cable. we have no cords that came with it. what do we need
You're going to need a coax cable about the length of the distance from your TV to your cable source, either the wall outlet or your digital cable box provided by your cable provider.
For good measure, get yourself an HDMI cable if you have certain digital cable boxes, DVD or Blu-Ray players. check out cablestogo.com for inexpensive cables. Don't get suckered into the expensive cable.
Good luck.
Apr 13, 2011 | Hitachi 42PD3000 42 in. Plasma Television
I can not access my hard drive all of a sudden
Please check the USB cable and the USB connector at hard drive enclosure, and also if it uses external power supply, check if any power indicator turns on when you connect it to a power outlet.
Mar 03, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi rear projrction tv. All of the rear connection are showing a output of 42 volts? Is the normal how can this be corrected?
Get a AC voltmeter and check between a known ground (outlet or water pipe)
If you read AC voltage on connectors one of two things is wrong:
1, disconnect cable or sat going to box and see if voltage still there.
2. If no voltage then, polarized plug has been defeated someplace in your home--what happens if large pin on any power cord with cable etc connected to the sets is the set is putting 120 volts via the cable connection to ALL SETS CONNECTED IN THE SYSTEM.
IF VOLTAGE STILL THERE WITH COAX UNHOOKED THE OUTLET IS DOING IT.
Polarized power cords were developed 40 plus years ago and the large side of the plug goes to the neutral side of the outlet--you are either getting it from the outlet or it is being fed back via the coax from another set.
Let me know if you have questions: THIS IS A DANGEROUS SITUATION AND NEEDS TO BE ADDRESSED.
IF THIS has told you something you did not know rate this solution as very helpful as I do this here for free.
If you have more questions LET ME KNOW--I AM HERE TO HELP.
SD TECH
Aug 18, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Just bought blue ray player I have a hitachi plasma tv model pw1 32pd5000 how can I get blue ray to work with tv theres no hd outlet at the back of tv but it is hd compatible
The TV most likely will have component and a DVI connector on it if it doesn't have a HDMI connector. If the Blu-ray player has component connectors on it use them as they will give you up to a 1080i picture which is all this model of Hitachi supports anyway. If the player doesn't have component connections then you can get a HDMI to DVI converter cable so you can connect it to your TV. You will need a cable that looks like this...
http://www.kmart.com/shc/s/p_10151_10104_25000PCM-2296-06P?vName=Computers%20&%20Electronics=&cName=HomeTheater&Audio=&sName=Accessories&psid=FROOGLE&aff=Y&sid=KAx20061023x272xTier3
Nov 11, 2009 | Hitachi P42A202 42 in. Plasma TV
Vhs hookup to tv
Try hooking up the AV cables, unless it's an older model(1993-1998) then you might require a coaxial cable. After this you simply plug it into the wall outlet, but I would suggest a surge protector for a Hitachi. If that does not work, then it is simply not compatible, but it should work, good luck
Dec 22, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 60SDX88B 60" Rear Projection Television Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
