Question about Gateway FPD1810 18.1" LCD Monitor
Can't get power cord
I got this monitor at a thrift store but it didn't have any kind of power cord. I have tried every power supply that says 12 volt but nothing will fit. We have also been told that other cords will work, but have not found one that will fit. I have tried calling Gateway but can't get help because it's not under warrenty. I have tried looking for replacement parts but can't find any that are even close
What is the monitor model and mark maybe i can help cause i got a gateway fpd 1810 and i got many power cord for it and fi got a universal power cord with 18 head plug from 5v to 18v. let me know at a2steven@yahoo.com
Posted on Jun 19, 2008
    Genius:
  • 2,985 Answers
I assume this model comes with an external power supply- that is a package that plugs into the out let. you can buy at places like Wallmart a universal power supply, that has a variety of connectors and a switch to change the voltage. the connectors have a colour code and match the voltage slider which also has a colour patch. Take a look at the monitor to see if the operating voltage is mentioned- but is does not matter. what you do is take a connector- not plugged to the cord and fit it to the power inlet- you get several connector and only one will fit -the right one. Match the the colour to the voltage slide on the power pack and you are in business- well maybe - I bet first time it will not work That's OK simply unplug the connector from the cord and reverse the pins [reverse the polarity] come back
Posted on May 22, 2007
What type of power supply is required for this speaker system? If available, how much can I expect to spend for the power supply? I have the speakers but no power supply.
Check the power-connector on the speaker for the rating:
* AC versus DC
* 4.5 versus 5 versus 9 versus 12 versus 18 volts
* 0.5 versus 1.0 versus 1.5 amps
* pole-negative-ring-positive versus pole-positive-ring-negative
Try the local "Thrift Stores", once you have the specifications. You may get the correct suppy for less than $5.
Apr 20, 2011 | Harman Kardon HK595 Computer Speakers
Tip
Finding lost charge cords, connectors, & adapters for 1$
Thrift Stores usually have bins full of all kinds of cords; chargers, connectors, adapters-you name it-and only a dollar each! I've found everything from expensive, top-of- the-line USB to USB cords to the oddball power cord to my old waffle iron. No matter how old or how new, common or uncommon, digging through the bins at your local thrift store saves not only money, but time and effort as well.
on Mar 17, 2014 | Electronics - Others
I need a replacement AC power adapter for FPE1080 TV
Hi, i have personally substituted laptop power supplies for those kind of televisions-make sure the power supply you get is of similar power rating, it should tell you the needed D.C. voltage and M.A. requirements maybe near the power jack-or somewhere on the label. Used power supplies are common at televised thrift stores. Just make sure polarity matches on power supply and tv-careful not to try and force jack into tv-it should slide right in. the voltage is usually 18 to 24 volts with an amperage of 2.5 to 4 amps, or 4000ma or something to that effect, hope this was helpful, Prodzilla
Mar 31, 2011 | Audiovox Televison & Video
Someone gave me an old Sylvania monitor (L15) Model no. PD-70FA but the 12V DC power cord is missing. It is not a standard type of powervcord and none of the stores I've been to (Staples, Office Depot,...
The power chord for this monitor is attached to a power adapter which converts mains voltage to 12 volts.
Check the power label on the monitor for the amp rating of the monitor and get an adapter that has an output of 12 volts and with the amp rating on the label or higher. Make sure the 0.3" power plug fits the monitor.
Feb 26, 2011 | Computers & Internet
Need ac power cord at best price possible
Check the local "Thrift Store" or "Dollar Store".
Don't pay more than $1 or $2 for the power-cord.
Oct 23, 2010 | Westinghouse L2046NV Monitor
I need a power cord for a Scanport 1920S 19 in. Flat Panel LCD Monitor
It uses a "standard" power-cord.
Look in any "Thrift Store" or "Dollar Store",
or buy at any small "mom-and-pop" computer-store -- they probably have a box-full of them.
Don't pay more than $2.
Oct 11, 2010 | Scanport GL-1920S 19" Flat Panel LCD...
I need an ac power cord for the daewoo monitor model # L523BM
Go to any say goodwill store or thrift store, the power cords they have any one should fit.
May 19, 2010 | Daewoo 17N5 17 in.CRT Conventional Monitor
I dont have a power cord for a monitor a friend gave me....what kind do i need? Model# 780 Product# E17Tr
99% of monitors use a "standard" PC power-cable, exactly the same as is between your computer's power-supply and the wall outlet.
Go to any "Thrift Store", and don't pay more than $1 for a power-cable.
Apr 05, 2010 | E-Machines eMachines Monitor E15T4
Need one 12v 2500mah power cord for flat screen monitor xenon is the brand name and is prob kinda old cheap if possible
I had a similar problem. Here is what I did:
I went to the computer store and I did purchased a generic Laptop power supply that provides 13 Volts @ 2Ah. y display was working fine with it.
You may be able to take the display information (Voltage, amperage, connector size, positive and negative information) and get assistance from a computer store (maybe radio shack, circuit cit... oops, they closed stores, never mind that one. Best buy or any electronic store in your area).
If that doesn't work or you can't get a similar power supply, you can check in e-bay and get one similar like this one:
http://cgi.ebay.com/12V-DC-Power-Supply-4-Amp-12-Volt-Adapter-LCD-CB-4A-HP_W0QQitemZ380155972539QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item58830fcbbb&_trksid=p3286.c0.m14
but you need to be sure about the positive and negative connector.
Good luck.
Sep 08, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
Any luck? I need the power supply cord too.
hello there:
If you have a thrift store or a goodwill store around your area they are a great place to get power supply cords and speakers and keyboards and power cords for these items ok:
please dont forget to give my solution a rating this really helps me out so i can help you out ok ?
best regards michael
Aug 19, 2009 | Harman Kardon HK595 Computer Speakers
Computers & Internet Logo
259 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
