Question about Nikon COOLPIX Cameras
Battery drains while camera is off
Used battery from a different S3100 and same thing happened. Camera drained new battery while turned off. Is there a setting I need to change to prevent this from happening?
  • 47 Answers
All of my research yields that this is a very common problem with this camera and there appears to be no solution that has been shared yet...that's why I didn't list this as a solution....sorry for not being able to help.
Posted on Nov 04, 2012
tjzteddy
  • 53 Answers
SOURCE: Nixon D40
Take it back to the store you purchased it from...this is a manufacturing defect.
Posted on Dec 29, 2007
mcomijohns
  • 477 Answers
SOURCE: Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Posted on Mar 22, 2008
dlundmark
  • 797 Answers
SOURCE: BATTERY EXHAUSTED
Make sure you have the internal menu for the battery selection correct.
Choosing the wrong battery may cause this.
Rechargeable batteries and alkaline batteries are not the same.
This may also be a condition and problem caused by the camera itself, and may need repair.
Posted on Sep 23, 2008
randy320sgi
  • 121 Answers
SOURCE: Nikon D70 will not power on after the lens was changed~
EDAWinc,
Is this a new or different style lens? You may not have it all the way on and aligned - try removing it again. Just remember to always turn off the camera before removing the lens or the SD card. Malfunctions are sure to follow if that happens. Try resetting the camera by holding down the two buttons on the top with the green dots for longer than 2 seconds (that works with the D80) The camera will not come on if the lens is not "on".
randy320sgi
Posted on Jan 09, 2009
I just had this problem today myself, and looked everywhere online for a solution. I changed the batteries (to Panasonic), and it didn't help. But i tried different batteries (Energizers) and the camera started working again.
Posted on Feb 17, 2009
I have a VPC-E870. Drains battery dead.
did you find a solution - mine does the same thing - and i bought a new battery - gone in a day - without even being used
paul
sanyo vpc-e870
Jun 15, 2010 | Sanyo VPC-E760 Digital Camera
My camera keeps draining the batteries. What is
A lot of things could cause this problem, there is no magic solution, but you can try to clean the battery terminals on the batteries, and also inside the camera...if they're oxidized, that will cause a high drain when the camera is on. Other than that, the batteries could be old and not holding a charge like they used to...rechargeables don't last forever. If you check these things, and still have the problem, the camera will have to be serviced to find the problem. Often the cost of service is more than the cost of a new replacement camera. I've seen 10.2 mp name brands on sale for $69, and you can't get one repaired for that, usually.
Mar 23, 2010 | Kodak EasyShare C140 Digital Camera
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Short battery life
Since you have a new battery and charger then we can eliminate that part of the hardware. That leaves an internal camera problem or how you are using the camera.
The #1 power drain is the flash. If you are taking a lot of pictures with the flash it will quickly drain a battery even if everything is working perfectly. You can try turning the flash off or down to see if this helps. The other thing is using the camera to look at your pictures. Not anywhere as big a drain as the flash but it does use some. As well using the camera to take videos or view them is higher drain. And taking big high quality pictures is more drain than smaller ones.
You may have an internal hardware problem in the camera itself. If the flash doesn't make a difference then I'd be inclined to think its the camera. If it looks that way to you after seeing what it does without the flash and so on then I would first check to make sure you have warranty and send it in to your local repair depot. You can find that by going to the Kodak web page and looking under support. You may want to talk to them and see if they can suggest anything else. And make sure you know what the replacement cost is before sending it in. Usually the repair cost is fixed but by the time everything is paid is shipping then it may be cheaper just to go get a new camera.
Sep 01, 2009 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Fujifilm S3100 won't power on
I'm not familiar w/ the S3100 but do you see any corrosion in the battery terminals? These camers don't usually just quit working. If the terminals are clean, what battery are you using? How many mA or milliAmpere rating? These are usually indicated on the rechargable battery's sides. There are some new battery in the market. The eveready silver colored battery. I forgot the name. It is one notch above the regular alkaline battery. Let me know if this helps.
Jul 20, 2008 | Fuji FinePix S3100 Digital Camera
Fuji FinePix S3100 won't turn on
there is a option in the menu that turns the camera off after 2min. and then after that it is hard to get started.I took out the rechargable batteries and installed new duracell batteries,and it started and then I went to the menu and disabled the powersaver option.
Apr 16, 2008 | Fuji FinePix S3100 Digital Camera
Camera Draining Battery
Lachuaeyes,
I have a different model of Olympus and I read that you did not always have this problem and you already have replaced the battery so an old battery is not likely the issue. I suspect you might have something that is draining that was not set in the past. I keep my batteries longer by not using flash most of the time. Is there someone new using the camera that perhaps leaves it on longer than you do after finishing, perhaps uses flash longer? Is there a setting for auto shutdown that has been changed to not turn off as fast as it used to? If none of these I wonder if the flash is requiring more energy than in the past.
Could you tell me if the battery is draining even if you don't use it or is it only if you are using it does it drain faster.
Another possibility is that the charger is not charging so well as it used to but I suspect you leave it in long enough and more.
If you have the ability to check the output voltage of the charger with a multimeter you would be sure it is really putting out enough volts to charge fully.
Please let me know if you have further questions.
HarryF
Dec 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Battery problem
Remove batteries and clean contacts of battery's host (include cover). Check as well that contacts are not bended and didn't lost their springiness. Good luck!
Aug 04, 2007 | Canon PowerShot A560 Digital Camera
Cameras Logo
75 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
