Question about Mitsubishi WS-73909 73" Rear Projection Television
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
  • 4 more comments
  • Joe Spina Nov 05, 2012
    I tried every button on the front panel with no success
  • SD Tech
    SD Tech Nov 05, 2012
    Here is a link to the owner manual, see page 57 and also note early in the manual the recessed reset button may work--http://tv.manualsonline.com/manuals/mfg/...
    The reset button didn't work and holding the menu button to unlock the keyboard didn't work. Is there a part I can replace to resolve this issue?
  • SD Tech
    The remote does turn set on and respond to numbers and enter and such?
  • Joe Spina Nov 06, 2012
    The remote and front panel only turns the set on and nothing else. .
  • SD Tech
    SD Tech Nov 06, 2012
    touchy issue as if remote numbers would work you could go into hidden menu and do a hard reset of entire set--at this point since you did the repair I would double check the keyboard etc are plugged back and no plugs are off or loose from the DM--that keyboard release should work but if keyboard issue...
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Posted on Nov 05, 2012
    Can find out what the exact button is I need to hold for the 5-10 seconds?
    I tried every button on the front panel with no success.
  • 1694 Answers
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Posted on Jan 07, 2008
SOURCE: Blinking green light stays on and TV won't turn on.
Green Blinking Light - Order a DM Modual from Mitsubishi. Read the plug labels when reinstalling.
Posted on Dec 14, 2007
SOURCE: PROBLEM WITH MITSUBISHI WS 55411
I had the same problem with my model as well. Luckily, I had the extended warranty and a technician came out and said that many people with TVs of this model have the same problem. He replaced the main system board and the problem was fixed. It has been about 4 months now and the problem just came back again. My TV is out of warranty now, but I hope I can get a warranty on that newly replaced party which appears to have gone bad again.
Posted on May 06, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Posted on Jul 28, 2008
  • 3 Answers
SOURCE: Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Posted on Nov 06, 2008
Ws 73909 has bad dm module. Where can I get it repaired or replaced?
If this is for the green blinking light issue, you can easily fix yourself if you have a soldering iron. It is just a few capacitors. But if you can't, then just about any mom n pop service compony will fix it for you, but will charge a lot of money to do it.
Mar 19, 2013 | Mitsubishi WS-73909 73" Rear Projection...
Replace the 7 capacitors on the DM board. That should solve the Issue. You can get the Mitsubishi WS48511 - WS65511 DM repair kit from www.tvrepairworld.com which has the upgraded replacement capacitors and the CD with repair instructions.
Jun 19, 2012 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi rear projection tv model ws65511. When i turned it on this morning all the timer light started to blink green. I tried to reset and it still blinks. unplugged and plugged back in and...
that's a very common problem for that model which is almost always caused by bad DM capacitors. Replacing them should solve the issue. You can get the Mitsubishi repair kit called the WS45511- WS65511 DM repair kit from www.tvrepairworld.com which has the caps and the CD with detailed repair instructions.
Oct 04, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Won't turn on.
Hi, If when you turn on your TV all you get is a blinking green light, you can find a lot of posts about this problem.  It usually is caused by bad capacitors in the DM board.  If you are handy and not afraid of pulling the DM board desoldering old capacitors and resoldering in new capacitors, this could be done for around $20 - $30.  You can look up Mitsubishi blinking green light or follow this link which gives a good discription of the process.
  http://hdtvoice.com/voice/showthread.php?t=32186
Hope this helps
Sep 02, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Blinking green light on my mitsubishi tv....model ws-65869
Replace the Capacitors on the DM board. You can get the WS55859 DM repair kit which covers your model from www.tvrepairworld.com which has the caps and the CD with repair instructions
Jul 14, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi tv model ws-65315, when i turn the set on, the green light comes on for a second then the set turns off what could it be
Check the voltages at the test points on the power supply. If the voltages are correct and all the fuses are fine, check for swolen capacitors on the format and the DM boards and replace them
May 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
MITSUBISHI WS-73909 will not turn on 1. I have a Mitsubishi Big screen TV model no WS-73909. Few days a go the city power went out when the TV was off. The TV had a surge protector. Then the TV will not go...
Are you a Quailified Technician ? Because this repair is not for the novice. The best thing I can tell you is contact a Mitsubishi Authorized repair center or tell me what area you live in and I can find one for you. cost is 250-350 to repair.
Apr 10, 2009 | Mitsubishi WD-65000 65" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Check for open pico fuse in power supply caused by bad convergence I.C.Get pro help-you have a good set to save.Remember--practice visual acuity technique!And,above all else,do no harm!!
Aug 26, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
Mitsubishi WS-73909 73" Rear Projection Television Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
