Question about Goodman Heating & Cooling
Manual for goodman/gue080-4 rev s - Goodman Heating & Cooling
2 Suggested Answers
SOURCE: Goodman GMP100-5 Rev Furnace Manual
Hi I have a Goodman Furnace GMP 100-5 with an AC connected to it. How should the wireing be connected to the furnace. It does not work when we turn on the heat. Currently the furnace has a brown wire coming out with 5 wires which is connected to the brown wire from the AC unit. The furnace also has a yellow, white, brown, and green wire hanging out. The thermostate brown wire has 5 wires and the yellow wire is connected to the red wire on the AC wiring and the red wire is connected to the brown furnace red, the green wire is connected to the green wire coming out of the furnace. The other 2 wires white and blue are not connected to anthing.What is the proper way this should be wired?
Posted on Jan 06, 2010
Goodman model PGB060125-1 REV wont run
whats not running i may be of further assistance with more info
Jan 28, 2017 | Goodman Heating & Cooling
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
I have a Goodman GMP 075-3 Rev B and cannot find the filter to replace it can you tell me where it is
I have the EXACT same problem. Cant find the filter and no manual came wit hthe furnace when I bought hte house!!! AGH!!
Nov 08, 2010 | Goodman GMS90703BXA Heater
I have a goodman 125-5 rev A furnace and it is showing a three blink error. what is this and can it be easily fixed or do i need to call a furnace tech. to look at it ?
FAN COVER SHOULD HAVE CODE LISTINGS .LOOK AT BOTH COVERS INSIDE AND OUT.  MANY CODES ARE PRINTED SOMEWHERE ON UNIT OR MANUAL. IF YOU TELL ME WHAT IT IS DOING OR NOT DOING I CAN HELP
Apr 19, 2010 | Goodman Heating & Cooling
Where is the pilot light on Goodman mod. PGB042100-1 REV A
This model has electronic ignition. You will need to remove the top panel, tape the door switch closed, have an assistant raise the thermostat above room temperature while you look thru the small window for an orange glow. If you do not see the glow, chances are you have a bad igniter.
Oct 18, 2009 | Goodman GMS90703BXA Heater
Need circuit board for Goodman GMNP-060-3 Rev B Furnace
Go to your nearest HVAC supply house. They should be able to get you it.
Apr 04, 2009 | Goodman GMS90703BXA Heater
Need a control board for a gmp75-3 rev 3 goodman
need the complete model and serial number to get to a site that you can order it through
Feb 14, 2009 | Goodman GMS90703BXA Heater
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
232 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
