My portable air conditioner runs but the compressor doesnt kick on
    Sergeant:
  • 293 Answers
Defective thermostat, compressor relay, or compressor.
Posted on Nov 06, 2012
SOURCE: My air conditioner doesn't blow out any air.
If this is a central air unit & you\'re talking about the fan on the outide of the house the problem may be that you are only getting 110 volts to the system side of the contactor. If you have the tools & know how you can check this yourself. If not, time to call a repairman.
Posted on Jun 01, 2007
SOURCE: 9000btu Haier portable air conditioner
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Posted on Jul 18, 2008
  • 30 Answers
SOURCE: Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Posted on Feb 01, 2009
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
SOURCE: need any user and -or service manual for delonghi PAC -75 U
Here is the manual
http://www.appliancefactoryparts.com/content/pdfs/123150.pdf
Posted on Jun 29, 2010
Danby portable ac
Check your Freon pressures. If you have no leaks, your low pressure switch probably needs replaced.
murf427
Jul 31, 2012 | Danby DPAC80201 Portable Air Conditioner
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
I cannot get my wintair room air conditioner to stay on! It keeps cutting on and off, going from fan to air conditioning. Need help!!
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Jun 28, 2010 | Heating & Cooling
Air conditioner shuts off and trips breaker on power cord
It sounds like a short or ground in the compressor. If you have an ohmmeter, unplug the unit and use the meter to check the wires to the compressor. Connect 1 meter lead to the compressor case then to the wires coming from the compressor 1 at a time. If none are grounded then connect 1 meter lead to the Com. Then connect the other lead first to the run wire, then to the start wire reading the resistance each time. neither should be less than 1. You can also check the condenser fan.
May 25, 2010 | Whirlpool ACP102PS Portable Air...
Lennox Diplomat 10AC48-1P, outdoor fan runs compressor will not kick on. Replaced contactor, still no compressor. Could there be an issue with dual capacitor or start capacitor that would prohibit the...
There could be the compressor capacitor is damaged.Sometimes on the duel capacitiors they will still run the motor,but doesnt have enough power to turn on the compressor.Or the compressor could be bad.
Aug 18, 2009 | Heating & Cooling
Jun 23, 2008 | Whirlpool ACQ108XL Air Conditioner
M6P09S2A-When compressor kicks in the lights in the room go dim
Call an electrician . Sounds like you are pulling too many amps. I wouldn't even run the fan....
Jun 09, 2008 | Maytag Portable Air Conditioner M6P09S2A
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
