Question about Dell Inspiron 560 MT Celeron 450@ 2.2GHz 2GB DDR3 RAM 320GB Hard Drive DVDRW Vista Home 64 Bit (609722305860) PC Desktop
Dell inspiron 560 won't recognize network adapter
We had a short power outage, and when the computer came back on, the network adapter is not recognized. When I try to connect to the internet, I get a dialog box that says Windows did not detect a properly installed network adapter. I have the resource CD/DVD for the computer, but the computer will not show the network adapter in the control panel. Any suggestions?
  • rrh90unc
    rrh90unc Nov 06, 2012
    So, it turns out Windows 7 had "dropped" the device driver for my network adapter when the power blipped. I was able to find a solution on the Windows 7 forum, which was to disable the network driver then restart the computer
  • rrh90unc
    The trick was to get the control panel to show all devices, even those that weren't working. I had to use the command prompt to get to that and use the directions I found online.
    Problem Solver:
  • 15 Answers
If there is no netework adapter in device manager or any device that is not instaled try checking in BIOS if it is enabled. sometimes after power loss bios is reset. if it is enabled in BIOS that short power outage probably killed your network adapter. you can add some PCI network adapter and solve your problem.
Posted on Nov 04, 2012
MerlinTech
  • 197 Answers
SOURCE: Can't find Network Adapters
you'll need to go to www.dell.com support, and get updated drivers(may take some time)
Posted on Jun 15, 2008
SOURCE: ethernet driver(s) for dell motherboard (0WF887)
inside operating system how do u make changes without deleting any existing files
Posted on Dec 22, 2008
  • 13 Answers
SOURCE: windows xp no longer recognizes my wireless antenna/program
It sounds like the problem you are having is that the controller for your wireless equipment is over-ridding the built-in Windows wireless controller. From what you stated in your question, the problem was solved before by reverting to the built-in Windows wireless controller (by re-installing Windows). The specific steps for your configuration depends on many factors (such as make and settings of the controller software/driver), I would suggest going to the control panel for the network adapters and opening the properties. Click on the "View Wireless Networks" button, if you don't see the list of available networks then there is an option to manage the settings from an external program. To solve the problem, revert to the built-in Windows controller; to give specific steps I would need to know more about your setup and installation.
The standard method is as follows:
1) Open the "Control Panel"
2) (For Classic View skip to step 3) Open the "Network and Internet Connections", then choose "Network Connections" towards the bottom
3) Double click "Wireless Network Connection"
4) Click on the "Properties" button (towards the bottom of the box)
5) Click on the "Wireless Networks" tab
6) Click the check box "Use Windows to configure my wireless network settings" (to put a check in the box)
Posted on Jan 03, 2009
  • 233 Answers
SOURCE: GMA 4082n device driver not working properly code 39
First go into Setup (usually F1,F2 or del) at start-up. See if your drives show up there. With Windows running, right click My Computer, left click Properties, left click Hardware, left click Device Manager, left click DVD/CD-ROM drives. Also check IDE ATA/ATAPI controllers. Do the drives show up there? If they do right click on drive and left click Update Driver. If they are not there go back to System Properties and left click on Add Hardware Wizard. This will search for devices. It may ask you to insert Windows CD which of course you can not do because the drives don't work. Try a different drive. When you cleaned out your computer did you delete or uninstall Office? That may be what caused this problem. None of this may work but it is a starting point.
Posted on Jan 06, 2009
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
My Dell Inspiron 560 will not eject a disk.
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
If you physically unplug your cd/dvd then plug them back in restart your computer the found new hardware wizard should activate
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Jun 03, 2013 | Dell Inspiron 560 PC Desktop
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Dell inspiron 560 problems
chek your video card it my be going out
Apr 30, 2013 | Dell Inspiron 560 PC Desktop
Intel celeron 560 won't shut down
Hold the power button untill the pc shuts down.
Dec 31, 2012 | Dell Inspiron 560 Desktop Computer (Intel...
Try reinstalling the NIC driver. If its separate network card, connected in PCI adapter, try to remove and plug it back in to see if its found after.
If these actions do not help, maybe NIC was damager with the power outage, it can happen.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Dell inspiron 1300 won't boot
If you want to keep your important data, use some softwares can solve thewindows won't startproblem most quickly, and no data will lose. Besides, it is very easy, even the people who lack of computer knowledge can deal with windows won't boot issue.
Sep 21, 2012 | Dell Computers & Internet
When I plug in my Dell Inspiron 1521 laptop, I get an error message saying it does not recognize my charger, will not charge and will likely slow down my computer's speed/performance. Everything...
Same topic on Dell official community, may it will help.
http://en.community.dell.com/support-forums/laptop/f/3518/t/7311465.aspx
There is high possibility that your adapter is stuffed. Dell have built in a recognition circuitry into the 65w adapters and when that goes, the system will no longer recognize it as a 65w adapter even though it is still putting out 65w. The system then shuts off the battery recharge circuit and to make matters worse it won't even charge the battery when the computer is off. It also speedsteps the processor down to half its speed so everything runs slower. Only option is to stick with a slow computer that can't be used on batteries or buy another ac adapter.
If you do not want to pay $80 for a original adapter directly from dell, there is an alternative choice to get an 3rd party charger, check this link below:
http://www.chargerbuy.com/replacement-dell-inspiron-1521-ac-adapter-19-5v-3-34a.html
Aug 02, 2011 | Dell Inspiron 1521 Laptop
My newly purchased dell inspiron 560 will not connect to the network due to "an invalid ip address". 10 other computers are working fine on the network. Any solutions?
You will need to manually configure the IP for your Local Network Connection: right click on the notification icon, go to Properties, double click Internet protocol version 4 (TCP/IPv4) Or click properties, click Use the following IP address and input the correct data according with the settings in your network - change just the IP first.
Jun 26, 2011 | Dell Inspiron 560 Desktop Computer (Intel...
Dell Inspiron 560 MT Celeron 450@ 2.2GHz 2GB DDR3 RAM 320GB Hard Drive DVDRW Vista Home 64 Bit (609722305860) PC Desktop Logo
515 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
