Question about Euro-Pro 9125 Computerized Sewing Machine
Thread tangling and jamming under the plate
This is a 2 year old machine that has never been used. I've checked the bobbin and seems to be in correct placement... however after a couple of stitches it jams. I've taken the plate off and cleaned everything and still it jams. I don't know what else to do
    Problem Solver:
  • 14 Answers
Check to make sure that you are threading the bobbin thread correctly in the bobbin compartment when you insert the bobbin; I was doing this with my old Singer after not using it for a really long time and had the same problems.
Posted on Dec 29, 2009
  • Annie McPherson Jan 28, 2010
    Please call Euro-Pro at 1-800-361=4639, extension 4. This is the correct number to call for help with sewing machines, and they've always been wonderful when I've called.
Sorry I do not have a solution but my Euro-Pro 1925 is doing the exact same thing yours is. Are you also getting a clicking sound and loose stitches on the bobbin side of the fabric? If you find anything out please let me know and I will do the same. I love my machine but I will never own another Euro-Pro product. I think the company sucks and does not stand behind their products. You can not find anything on the 1925 model and no one that can service it either. Thank you, Erica my email is erica_jennings@sbcglobal.net Funny thing is my machine is only 3 years old.
Posted on Jun 06, 2009
2 Suggested Answers
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
Machine jammed and now the bobbin wheel will not turn or catch the thread
By jammed do you mean thread jam? Have you removed sew plate and checked under feed dogs and bobbin for tangled thread and lint build up?
Mar 30, 2017 | Sewing Machines
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
Bobbin thread tangled
Try these suggestions and see if they help
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Dec 22, 2013 | Baby Lock Ellure
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Aug 20, 2013 | Baby Lock Ellure
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
Bobbin jamming
clean under the needle plate & in the bobbin area for lint
rethread the top part of the machine using every thread guide
if none of theses suggestions work, the machine needs to be
checked to see if there is a problem with timing
Sep 21, 2012 | Bernina Virtuosa 150
Brother 700e
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
When sewing the thread under the material gets all tangled up. The thread is also tangled in the bobbin. At times the needle doesn't even pick up the bobbin thread, but that is another issue.
have you tried a new needle?
the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
4.also clean under the needle plate for lint & loose threads
check to see if the thread has come off the thread take up lever
Sep 12, 2011 | Necchi Sewing Machines
The thread keeps jamming under the feed dogs. The machine takes about 2 stiches and then it won't move any more, but it keeps sewing making a terrible mess under plate. What can I do to fix this...
I had the same problem and tried everything you did: rewinding the bobbin, checking to be sure I had the bobbin in correctly, checking the upper threading, readjusting the tension. When nothing I tried helped, I bit the bullet and took it to the shop where I had bought it. The timing was off; there were burrs on the bobbin case; the hook was not performing correctly;there were threads caught between the tension disks. It cost about $65 but when I brought it home, it purred like a kitten! I suggest you take it in for a check up! Especially if you've tried all the usual tests and none of them worked.
I'm sorry I couldn't give you a do-it-yourself answer but sometimes they've just gone beyond what we can do for them.
Jul 24, 2011 | Brother SE350 Mechanical Sewing Machine
Euro-Pro 9125 Computerized Sewing Machine Logo
200 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
