Question about Toro Garden
Tecumseh vm80 carb set up - Toro Garden
3 Suggested Answers
  • 110 Answers
SOURCE: I have a vm80 8hp tecumseh engine 150092D day
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
Posted on Sep 25, 2009
  • 151 Answers
SOURCE: How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Posted on Dec 27, 2009
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
Just installed a new carburetor on a Tecumseh Snow King 8 hp engine. Gas is getting to the carburetor but no gas is filling the bowl and engine won't start
Sounds like the carb needle valve is stuck closed. Try loosening the bolts holding the carb to the engine, then tapping the carb lightly with a hammer. If gas then flows to the carb, re-tighten the carb bolts evenly and not too tightly.
Dec 27, 2014 | Tecumseh Garden
Tecumseh ohh55 smoking/burning oil
http://www.repairclinic.com/Tecumseh-Small-Engine-Model-OHH5569024F-ID-806444-Parts
one of many suppliers on the web- lol
Jan 07, 2012 | Tecumseh Garden
Dec 21, 2009 | Toro Garden
Sep 25, 2009 | Garden
I have a craftsman lawn mower with a tecumseh engine model# 143.956000 carbuator #(# on carb)1538F5R i need to know if the spring on the main jet goes on top or under the main jet. i got the carb in pieces...
LOOK CLOSE ON THE CARB THERE SHOULD BE A NAME OR SOME LETTERS OF WHO MAKES THE CARB GO ONLINE TO TECUMSEH AND YOU CAN GET A CARB BREAKDOWN DON'T GO TO SEARS TO MUCH RUN AROUND
Aug 22, 2009 | Tecumseh Garden
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh HM80 engine, new carb, won't run
Not the solid state ignition. If this were the problem the engine wouldn't start at all. There is some adjustment needed to the carb but without more info, I'm not sure what.
Jun 17, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh HM80 on coleman generator. won"t stabilize, backfires. new plug, fresh gas 'carb cleaned. starts first time'new air filter. any suggestions?
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Mar 01, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
