Question about HP Pavilion Computers & Internet
Video display driver stop working and blue screen appears while running and also does not start
  • HP Master
  • 7,627 Answers
Try Cold-Start, shut down, unplug, remove battery, hold down on/off button for 10 secs, replace battery, plug in push on/off button try to start normally. If that fails try starting in safe mode to troubleshoot error.
Posted on Nov 04, 2012
2 Suggested Answers
patemi
  • 366 Answers
SOURCE: i have a m6805 gateway
From gateway web site check if a new driver is available for your model
Posted on Jan 12, 2009
Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
follow this steps and fix it. God bless you
Instructions 1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 15, 2013 | Exercise & Fitness
Display driver fails while watching videos
Are you watching the video on-line? From the DVD/CD rom drive? What is your OS? Windows 7? 32 or 64bit? Is this a recent occurrence? I'm sure you have done ALL your Windows and HP updates, if on-line have you tried another browser? If you haven already looked the drivers can be found here, choose your OS: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=4290955& Have you verified the machine is clean and free of dust in the fan, vents, heatsink? No Overheating? Getting proper air flow? Only use the drivers from the HP site or Windows updates. Take a look at this: http://wer.microsoft.com/responses/Response.aspx/3319/en-US/5.1.2600.0.00000000.9.9?SGD=4542898f-63c3-41eb-9b3d-a7551af82955
Apr 01, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Blue screen error appearing while installing Windows XP. I cant install windows xp. plz help me. I want to install windows xp.
format the drive in which you have XP before , then install a fresh copy of XP
then when XP's finished first of all Update your drivers first.
Find out what graphic/video card you have.
Start Menu > Run > Dxdiag > Go to the Display Tab >
It should say the Name of the Graphic/Video card.
After you find out the name just google the card and find the drivers.
Install it and see how it works. good luck do vote
Mar 31, 2011 | ASUS K8V-MX Motherboard
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
***STOP: 0x000000EA(0X81D46020, 0X82849438, 0XF8911CB4, 0X00000001) ati2dvag begining dump of physical memory hardware device vendor for driver updates this appears on a blue screen after my pc stops...
The video driver is corrupted. Uninstall the one you have now from Programs, reboot at least twice then download (as in Save, not Run) the latest one from here
http://support.amd.com/us/gpudownload/Pages/index.aspx
Wait for the download to end and install it.
If you get the same after that then the video card is dying, replace it.
Jan 13, 2011 | Gigabyte GV-RX13P256DE-RH RADEON X1300...
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Blue Screen
please remove battery and ac-power for a couple of minutes and then try to reboot the computer.
if it still doesnt work, shut it down, remove battery and ac.
remove ram
connect ac-power
try to boot without ram
remove ac power
insert ram
insert battery
connect ac and try to boot again.
when the blue screen appear, please write down the top line that looks something similar to this:
IRQL_LESS_OR_NOT_EQUAL_ETC_ETC
and the line close to the bottom that says
STOP: 0x000021 (0x000+++alot of not needed numbers)
when you have done that please come back to me.
May 29, 2009 | Acer Aspire 4520-5141 Notebook
Stop Error (Blue Screen) XP/7000 VE/AGP
sounds like might be a bad card,
alternatively your system ram might be giving you grief, i had major BSOD issues with my computer and ram tested fine, upon switching sockets that the ram was in i found that it was actually good ram, bad ram socket.
Mar 05, 2009 | ATI RADEON VE (32 MB) Graphic Card
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Feb 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Camcoder (Panasonic PV-GS15) does not play back recording
Sorry to say- but it is trashed.. It would cost more to fix it than it would be to buy a new one.
May 06, 2017 | Panasonic NV-GS10 Mini DV Digital...
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
