Question about Hobart D340-6007 Mixer
We have an old hobart mixer,when we turn it on it won't go into gear,,can't get any gear to work
  • 1 more comment
  • Dennis Boxerman May 11, 2010
    Need more info. Will it go into gear prior to turning it on? Does it run but nothing moves? Need more info. Model, serial, ML# world help.
  • Rick Belanger
    Rick Belanger May 11, 2010
    Please state the model name, serial number and ML #. How did it stop working properly? Has the shift lever been removed lately? ricardok45
  • David Shaub May 11, 2010
    Does the motor turn?
    Are you trying to put into gear while it's moving or stopped?
  • 20 Answers
You do not say what model mixer you have but more than likely the shifter yoke is faulty
Posted on Aug 08, 2009
I want to know if the mortar mixer D 300 Hobart make a changefor the gear because my speed number one doesn't work
Of course there are spares for Hobart mixers. They have been supplying spares for these machines for many, many years. We have an A20 (which is slightly smaller) and this, although it is about 40 years old, it is still supported.
Jan 23, 2015 | Hobart Food Mixers
I have an old Hobart 5 quart N50 mixer (4749). There is a phenolic gear which is driven by the gear on the motor shaft, and this gear is starting to delaminate at some tooth edges (about 1/8"). ...
The gear has not really changed. It is a fail-safe gear designed to break before the motor is damaged by the transmission being jammed.
As to whether it will last, I can't say. I know of no other sources for the gear other than keeping a watch of Ebay.
Jul 28, 2017 | Hobart N50 Stand Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Jul 23, 2009 | Hobart D300 Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
Hobart vertical mixer/cutter
IS THE OLD DRUMP SWICH IS BURN CLEANED OR CHAGE IT. GOOD LUCK.
Apr 29, 2008 | Food Mixers
HOBART A-200 MIXER- FIRST GEAR NOT WORKING
Hi, your mixer was manufactured in 1947. Hobart does not make public their service manuals. It sounds like the diving key is not engaging first gear with the spinning shaft. This is the ticking sound you hear/feel. This could be because of a broken spring in the mechanism that moves this key in and out, or the key itself has become so worn that it will no longer engage the first gear. The unit needs to be opened up to remove all old grease and oil, including the planetary. The condition of the grease in your description of the planetary, is a good indicator of the condition of the grease in the trans. Your unit probably needs an overhaul due to it's advanced age and grease state. Unplug the unit. You can gently remove the two circular metal dust covers underneath the top cover. With a good flashlight you can view the overall quality of the grease and the level of it. In an ideal world the grease should fill the entire cavity and no oil should be visible. Replacement grease should be Shell Darina EP-2 or Chevron ALC EP-2. You'll need 4-14 OZ. tubes of either type to do the job. The Spec. # for your unit is 3943 Look for drawing # PL-985 Once the cover is off the trans., it's relatively easy to get to the diving key once you remove first gear (the large round gear on top). Remove what you need in sequence, and replace in sequence. If you have a digital camera, take lots of dissasembly pics. When you are done, test in all gears by turning the motor cooling fins with your fingers in the normal direction of the motor rotation. Do not plug the unit back in until you've tested all speeds manually. Good luck! ricardok45
Jan 30, 2008 | Hobart A200 Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
Jan 11, 2008 | Hobart A200 Stand Mixer
Trying to find gears for an Old Mixer
sorry my friend but that is a very old mixer and we dont sell them anymore (im a tech for hobart).the only suggestion i have is to find a machine shop in your area and bring them the old gears and see if they can machine them for you.are they broken?whats the problem.
Nov 02, 2007 | Food Mixers
Hobart D340-6007 Mixer Logo
129 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
