Question about Lux Tx9100e 7 Day Universal Programmable Thermostat
Honeywell LR69071 with 7 wires to LUX TX9100E - Old Honeywell (wires labeled G O L R W2 X Y1; jumper from W1 to Y1) vs. LUX (labes for C B O W Y G RC W2 RH A) - Where in the world do the wires go on t
This is supposed to be a universal thermostat, so I'm hoping they didn't give me one that doesn't suit my system. Where do these 7 wires go on the new thermostat? Please help!?! : )
Wall furnace non pragramble wiring code
Judith that information is on the package or information sheet provided .they even provide labels to mark your wires with .
Nov 22, 2015 | Honeywell Ct87n "the Round" Heat/cool...
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Nov 22, 2015 | Honeywell Digital Round Thermostat,...
How can I make a thermostat connection?
Good morning Yakup.
The best way is to write down how the old t-stat was wired. If that's not available, the only way to determine for certain where each wire goes, is to check what the installer did at the terminals in your home comfort system. Please note the there is high voltage electric in each piece of equipment so if you decide to open up panels, there is always the risk of damaging the equipment or worse, injury or death if you are not a qualified service technician. However, typical color assignments are as follows:
R= (24v from heating appliance) Red
RC= (24v from cooling appliance) Red
These two are only separated when you have two different appliances providing seasonal comfort, like a boiler and an air handler. If you have a warm air furnace with an air conditioner or a heat pump attached then R+RC will have a jumper across them and only one RED wire will be landed there
W= (heat) White
Y= (cool) Yellow
G= (fan) Green
Those colors are pretty standard
The rest of the colors depend on availability in the jacket and are really up to the installer. You mentioned 7 wires but 8 conductors is more likely so I'm assuming the remaining colors are black, brown, blue, and orange.
I always use the following:
C= (common) Black
O/B= (reversing valve for a heat pump) Orange if the valve is energized for heat and Blue if the valve is energized for a/c.
Aux/E= (auxiliary or electric heat) Brown
L= I believe this is a diagnostic terminal for some systems with feedback data and is not used frequently.
After wiring there is some programing to do to set up your new thermostat to your type of system.
Hope that helps. God bless and be careful.
Aug 06, 2014 | Honeywell RTH6350D1000 5/2Day Prog...
Honeywell ct87n wiring schematic
These are color codes wires for terminals that control fan relay,start,stop, temp-up/down ect. Also you can trace out those wires, Where they are going and what terminal on the wiring schematic they control.
Jun 27, 2014 | Honeywell Ct87n "the Round" Heat/cool...
Display all 888s
All you can do is remove batteries for 5 minutes or so , then try again.
Feb 18, 2014 | Lux Tx9100e 7 Day Universal Programmable...
Lux TX500e thermostat
go to honeywell it,s a house hole name
Nov 07, 2013 | Lux Tx500 Series Smart Temp Electronic...
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
Changed to lux9100e thermostat and get reversed polarity message on bryant furnace
I think it means that you need to reverse the wires to their respective connections on the thermostat..
Sep 24, 2012 | Lux Tx9100e 7 Day Universal Programmable...
Replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Nov 14, 2008 | Honeywell Water Heaters
Lux Tx9100e 7 Day Universal Programmable Thermostat Logo
62 people viewed this question
Top Lux Water Heaters Experts
Gene Haynes
Bill
Level 1 Expert
Are you a Lux Water Heater Expert? Answer questions, earn points and help others
