How to exit this corrupted installation laptop acer keeps restarting trying to install . Not able to access desktop ! Watch video ! No disc installation ! Need Help
  • Computers & ... Master
  • 15,557 Answers
Start the computer and then immediately start tapping F8 and see if you can get to menu that says safe mode. Let us know if you select safe mode if it will boot
Posted on Nov 04, 2012
SOURCE: ACER ASPIRE 3680 WINDOWS ERROR RECOVERY
hi
you said u did try to press F2 or F8 to get to bios setting, are you saying pressing these would not open bios setting windows?
shakeel
Posted on Nov 06, 2007
cpenzes
  • 1102 Answers
SOURCE: WINDOWS ROOT
your just missing files usually caused by recovering using battery power
make sure you are using ac power only restar system
if you still get error then with cd in drive restart press f7 and a box will appear choose option cd cd\dvd then press enter
and follow instructions.
Please let me know if this has fixed ya
and don't forget to rate me
Posted on Feb 04, 2009
  • 289 Answers
SOURCE: Wireless network
hi..u need to install the nerwork adapter to
make your wireless work.so first install the
network adapter to use the wireless.
try this out..
thank u..
rate me..
Posted on Feb 09, 2009
babes_ganda0
  • 381 Answers
SOURCE: installing acer launch tools in aspire 5920g model laptop
you need new installer windows and you need manual install you're recovery programs is corrupted..try to use new installer...
Thank You
Posted on May 05, 2009
RescueTechLA
  • 2653 Answers
SOURCE: erecovery acer 5315
You can "try" to stop the process from starting by unchecking the appropriate box under boot menu.
go to RUN, type MSCONFIG, check the startup tab.
Hope this helps.
Posted on Jun 15, 2009
Need command at boot up to access disk image to remove corrupted partition and fresh install
If there a corruption on the hard drive you might not be able to boot up on it. Instead try downloading Ubuntu for the desktop. This should allow you to boot up using the CD, don't install the software just use it from the cd, it should give you access to the hard drive.
http://www.ubuntu.com/download
May 09, 2015 | Acer Aspire 5600U all-in-one desktop
I tried to install windows 8 and the installation was interrupted now it restarts every time because it wants to fix problem but nothing happens and I cannot access the desktop how do I get rid of th
Are you installing from a cd/DVD? Since the program has some corrupted files from the interrupted install you will need to start over. Have the Win8 disc in the tray and restart the computer. Just follow the instructions to restart from the DVD. The program needs to get ALL the files onto your hard drive for it to finish. Hope this helps you.
Nov 03, 2012 | Computers & Internet
Acer laptop saying bootmgr compressed type in password at start but keeps going to bootmgr compressed cannot access any thing
To solve this, you need the install, update or recovery (Win7) disk for your version of the Windows OS. (I am assuming you do not have Unix on the machine.) Make sure to match the service pack and specific version (Home Basic, Premium or Business for Vista (32 or 64-bit), Home or Pro for XP) installed. The Windows 7 install or upgrade discs have the contents of all the options. If you have a laptop without an optical drive, you can run the files from a USB optical drive or thumb drive.
Put this disc in your optical drive and restart your computer. Press F12 repeatedly as the computer starts. This will give the Boot Options menu. Select boot from CD or USB as needed. Let Windows load from the optical drive and then choose the Recovery option. You will need to use the Command Prompt option. Then type "bootrec /FixMBR" without the quotes and followed by enter. Then type "bootrec /Fixboot" (as above without the quotes and followed by enter). At the next prompt, type "bootrec /rebuildbcd". When you get the next prompt, type exit.
Now restart the computer. If one of the above steps failed, you may need to reinstall your OS. Another option to try is to Validate and Fix the File System. From the same recovery disc command prompt, type "chkdsk c: /r" to repair the boot process.
I hope this helps.
May 20, 2012 | Computers & Internet
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
Aug 28, 2011 | Acer Computers & Internet
I have an acer aspire 5100. it stopped working yesterday and won't let me log in. on a black background, it says: --------------------------------------------------------------------------------- Window...
You PC note book needs to be reformatted do the following:
1. Restart
2. Press "F2"
3. look for the default bios settings.
4. exit and save
5. restart you notebook PC remember that you must insert the flash drive containing the windows installation since notebook PC doesn't have CD drive.
6. run installation and w8 30 minutes and provide valid cd key for windows.
Dec 26, 2010 | Acer Aspire 5100 Notebook
Computer keeps rebooting
your windows is corrupted so please reinstall the windows
Sep 28, 2009 | E-Machines eMachines Desktop PC
Installing acer launch tools in aspire 5920g model laptop
Thank You
Apr 03, 2009 | Acer Aspire 5920-6335 Laptop
Ho w do i load windows onto an acer laptop
dear first you
formate the c drive and insert a windows softwae cd into the cd drive and follow the instoction.wait for 45minites it will complete windows install
after sucessful instalation you have to restart your laptop.
Nov 12, 2008 | Acer Aspire 5100 Notebook
Acer 3050 1554 No instalation disc
nope..where did you get the acer from? Go there, and get a system recovery disk.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
