Question about KitchenAid KBRS19ktwh Bottom Freezer Refrigerator
Kitchenaid refrigerator not cold - KitchenAid KBRS19ktwh Bottom Freezer Refrigerator
Kitchenaid superba refrigerator side at lowest temp setting is not cold enough. Freezer temp is fine.
Check the setting of your vents between sides and open them, sometimes you have to pull out the produce drawer to find the lower one
Jun 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
My KitchenAid Subra fridge. it seems like the freezer is always producing cold air. It keeps the freezer so cold that it freezes the drain plug were the condensation is suppose to drain out of the freezer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Mar 23, 2011 | KitchenAid Refrigerators
The freezer is leaking water out the bottom model #ksrg2tfkst18 kitchenaid
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 20, 2011 | KitchenAid Refrigerators
KitchenAid refrigerator. Freezer works - refrigerator is not cold.
turn your letter dial to about c that should let in cold air from freeze.. ok
Feb 11, 2011 | KitchenAid Refrigerators
Our KitchenAid Refrigerator Model KTRS22EM is not freezing or cold enough in refrigerator Indicators are all at maxium , cleaned coils and you can hear it go on but not getting cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 01, 2010 | KitchenAid KTRS22EM Top Freezer...
Kitchenaid KTRS21KDAL refrigerator not cold but freezer is
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jul 16, 2010 | KitchenAid KTRS19KKSS Top Freezer...
Refrigerator side not cold
if you have frost build up on rear wall of freezer section then your unit is not going through defrost. its either defrost heater, defrost thermostat (which are both located on evaporator) or defrost timer
Jun 24, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid KBRS19ktwh Bottom Freezer Refrigerator Logo
26 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
