Toshiba Model 57H83 Rear Projection TV Lost Picture and Sound
It was working fine last night. No problems with picture or sound. Today, I turn on the power, the red light comes on but then nothing.....no picture and no sound.
  • Shirley Nov 05, 2012
    Thanks everyone for your help! I will show these solutions to my son and see if he can resolve; if not, we may just have to get a new set. (I don't really want to....I really love this TV). Where is the best place to get parts? I have been reading that there are a lot of defective parts direct from Toshiba. (mostly bulbs)
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The most common problem in this set is convergence---two chips are used and if one shorts what you have happens--only way to prove this is get at and unsolder all 18 pins on both chips----if set turns on then the chips and or a resistor near them are bad.
Soldering and getting at the chips requires some skill--the parts involved usually are under 30 dollars total.
set uses chips like these:
Toshiba Model 57H83 Rear Projection TV Lost Pictur - 11_5_2012_4_06_58_pm.jpg
Posted on Nov 05, 2012
  • 81 Answers
SOURCE: Mitsubishi WS-65809 turns off right away
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
Posted on Apr 05, 2007
SOURCE: Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Posted on Sep 11, 2008
  • 7 Answers
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: Toshiba model 61h71 red light comes on /no picture or sound
We had the same problem, open the panel on the back of the tv, the board on the left, not the one with the convergence chips. Inside the tv u will see a piece of paper with the fuse info. The board on the left unscrew it and flip it away from you, the fuses to test are at the bottom, on the circuit board it will say 125volt 5 amp, and the number starts with an f. they are small and rectangular and black. Check all but the 3 at the bottom are usually the culprits Hope this helps u
Posted on Mar 24, 2009
SOURCE: No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Posted on May 18, 2009
Toshiba 57H83 and no longer get any sound. Any
Most often No Sound with Toshiba 57H83 is:
1. TV has a Sound on-off switch on the input panel at the rear of the TV. Very hard to see, black on black. Used to turn off speakers if you use a separate or external sound system for speakers. Usually gets moved while connecting hd cables or dusting and vacuuming in cramped space at the rear of the TV.
2. Someone accidentally changed Sound settings with remote to CC (closed caption) or SAP. Turn off in sound menu and save preference.
3. Sound input plugs from external cable or sat box unhooked or wrong input.
Toshiba 57H83 no sound fault is not common. If you still have no sound, get local service.
Or troubleshoot yourself to determine if Tuner, IF, processing, sound demod, switching or sound output circuit is smoked. Then make an installation plan.
easyab
ConvergenceRepair.com
Feb 28, 2010 | Toshiba 57H83 57" Rear Projection HDTV
No picture
Your sweep module has gone out. Probably be lucky if can find part for this set.
Sep 08, 2009 | Zenith IQA56M98W 56 in. Rear Projection...
I've got a toshiba 57H83 rear projection tv. Last night it crackle and went out. The power in the front was flashing. So I unplugged it and plugged it back in and it sounded like an electrical short. Could...
I have had a shorted picture tube do that on a Toshiba before. It could also be a Flyback transformer arcing.
You should call a good TV Tech for an estimate.
Aug 05, 2009 | Televison & Video
Toshiba model 53h71 will not turn on
I have the same problem - just happened last night. I found this posted on this sight. Does your problem sound the same?
http://www.fixya.com/support/t1482810-toshiba_57h81_flashing_red_power_light
Feb 03, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 57h83 wont do nothing
that relay is supposed to engage power to the tv boards that control the screen.
you will have to take it to a oualified service center , because they have access to parts that are needed for repair
Oct 17, 2008 | Toshiba 57H83 57" Rear Projection HDTV
Loss of picture and sound
Is the front panel power led flashing by chance?
Jan 09, 2008 | Toshiba 57H83 57" Rear Projection HDTV
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
