Question about Numark TT200 Turntable
I have a pair of Numark TT200 , bought used in Canada (115V network voltage). Now I want to connect to the German 230V. According to the TT200's manual, there should be a small switch next to the
  • ap_daun
    ap_daun Nov 07, 2012
    Problem solved - the area of the caseing on which the voltages were printed, next to the power jack, is removable and can be inserted in the proper orientation for the voltage, as indicated by a small arrow.
4 Suggested Answers
  • 69 Answers
SOURCE: Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Posted on Aug 07, 2009
Grubhead
  • 5126 Answers
SOURCE: my numark tt200 turntable doesnt output anything
Have you replaced the cartridge? If you have it might be an internal pre-amp problem inside the deck.
Posted on Nov 27, 2009
  • 44 Answers
SOURCE: Does the numark tt200 have an auxiliary output? Do
do'se it have auxiliary hookups in the back if not then buy a preamp
Posted on Jan 03, 2011
Numark C3usb - how to replace a fuse
Trace the inout power wiring. You will find a fuse someplace very near where the power comes in. Note that they MAY be one of several types that don't look like common glass fuses. ALSO a common thing is that the fuse is in a little "boat" that is right adjacent to where a standard line cord like on tower PC's use. This boat has to be pried out to get at the small fuse in it. Choose the right size fuse for the 230 v operation.
Mar 04, 2013 | Numark Industries Numark C3usb Rack Mount...
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
I just bought a AOSmith 1hp pool pump. I do not
Well first did you have an old one you're replacing? Check it. Second you could test your voltage with a tester (best idea then you know for sure). Third, you can look at the circuit breaker in your panel, and if it is a single breaker , it is 125V If it's a double pole breaker (two wide with wide handle) then it's 230V. Usually if it is 230V then the wires coming to it would both be black, or black and red, with a bare or green ground. Usually if it's 115V you'll have one black (hot), one white (neutral) and one bare or green(ground) but at times someone will wire one 230 with black and white. There should also be a large bonding copper jumper connected to a lug on the outside of the motor to bond your system to the pool (NOT AN EQUIPMENT GROUND)
Jul 05, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
I bought two numark ttx usb turntables of ebay with no warranty, they were from the usa. one of the turntables works fine the other did not even turn on at all. i thought it must be that i did't flivk the...
Here is a copy paste from Numark's Quick start owner manual page 3:
3. Voltage Selector:
This switches the internal voltage transformer between 115V, 230V and 240V. The turntable should be shipped with the proper voltage setting for your region. Check that the switch is in the proper voltage before connecting the power cord to prevent damage to the turntable.
At page 2 also there is a diagram showing the exact place for that switch.
So I can't believe that this turntable is stricted for use under 115V. Also, as far as I know from my experience (23 years Electronics Engineer), the only thing that coulg be before the transformer is either the voltage selector switch, or some kind of ac filter. The only case that I'm not sure, is the case that you powered up the turntable at a 230V area and the Numark's voltage selector was set at 115V. In that case the transformer should be burned and the service should replace it and charge you the cost for that.
I think that there is something strange at your case. Why don't you check at another service center at your area?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 13, 2010 | Numark TTX1 Turntable
Platter will not spin when play button is pressed
i recently bought a pair of numark tt 200s and one of them had this problem,but because i bought them from cash converters i took them back and the technician there had a look at it and said it was the motor.
But he didnt say whether the motor could be repaired or whether it needed to be replaced.
I Have not had any luck in solving this problem yet
Jan 27, 2010 | Numark TT200 Turntable
My motor is wired for 230v and I need it to be 115v
It should be. Look closely at the motor nameplate and you should see a small diagram telling how to connect the motor for 115v or 230v. Most newer pumps have a small selector of some sorts. Either a plug that pulls off a couple post the include an idicator arrow for where to set the plug for either voltage, or a dial you turn to show it. Either way, you should be able to set the motor for 115 rather easily.
Jun 14, 2009 | Pentair Whisperflo 3/4 Hp 115/230v
Took apart tone arm of a Numark tt200
On this PAGE you will find each and every part of any component of the the TT200 for sale from Numark, including an "S" arm.
Replace, do not fix,. the arm for this HIGH TORQUE lathe.
May 02, 2009 | Numark TT200 Turntable
Numark tt200 motor
The knocking sound is NOT normal, and you should not ignore it.
The tt200 is a HIGH TORQUE turntable, and as such is a highly accurate lathe for the accurately determined speed of the platter.
The lathe is in need of adjustment, which is recommended.
Apr 06, 2009 | Numark TT200 Turntable
Just need this manual if possible
I need Service Manual on Nuwmark TT200, turntable, motor inop, Ic TA7259P need to know the layout, has power supply voltage an regulators seems to be ok, comes on but motor inop.
Thanks David Williams Email davidglenn7@yahoo.com.
Mar 30, 2009 | Numark CDX Turntable
Numark TT200 Turntable Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
