Question about GE Spectra JBP78 Electric Kitchen Range
Ge oven clock and oven dont work
My ge oven clock and stove stopped working when i plugged it in.
what can it be
  • 163 Answers
Hi!1 your control board is shorted need a new control clock board..Just remove the screws to the top back panel and you will see the the main board easy to fix..Just buy main clock board..Good luck..
Posted on Jan 04, 2009
My stove is a GE and everything works but the burners and oven.
check your breakers everything you said means not enough voltage
Apr 05, 2014 | GE Stove/Oven/RanSurface Burner Knob -...
Americana stove not heating but lights come on
get in an electricians to check what looks good but isn't
May 29, 2017 | Ovens
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Display goes blank, no heat, no oven
This I hope will be an easy solution for you. I think you have a circuit breaker tripped or a fuse if you have a fuse panel.. I am guessing you have an old fuse panel. When you have a fuse blown on a 230 volt appliance and you turn a swith on (like your knob) it feeds back to other circuits on the 120 circuits and will make it do crazzzy things, like making lights and clocks work..Regardless if you have fuse or breaker you dont have the 240 volt to run the range..You only have one120 volt leg powering your stove.
Nov 03, 2008 | GE Kitchen Ranges
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
361 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
