Question about Yaesu FT-890 Technical Manual
Alc does not function properly when I exceed 70 watts in transmitted output
Adjusting the mic gain does not solve the problem
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi francis,
Firstly, what is the maximum RF power of your radio?
If it's below 70 watts, there is your problem.
If on the other hand it's 70 watts or more, then try this:
join yahoo group specific to your radio Make/Model, the team there will require as much detail as you can give them so they can help you rectify the fault. You will receive great advice and info plus, you can download manuals, diagrams and other goodies for your radio and all of this is free.
I hope this has been useful to you.
Best regards,
Peter
Posted on Mar 07, 2013
Cobra 29 ltd classic year 2004. rf gain problems.
Put SWR meter between your antenna and output, test wave length receive/transmit, might need a ground plane or center loaded stick.
Could be transceiver relay, try clicking mic fast, it should click out as fast as you key the mic.
Oct 26, 2016 | Cobra Radio Communications
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Apr 29, 2016 | Yaesu FT-857D transceiver
Distortion in my mic
Adjust the preamplifier level to approx. 9-12o'clock on the input trim.
Then adjust the master level to the desired output.
More about proper gain stages HERE:
http://www.homebrewaudio.com/what-are-gain-stages-in-audio-recording-and-live-sound/
Nov 06, 2013 | Shure Audio Players & Recorders
I have a galaxy 88 and when u try to use it on ssb the radio will only do half power even with ssb power all the way up!
there is a ssb regulator bad or the power is turned down
this how to adjust ssb power output SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 500 Hz and 2400 Hz, 30 mV (-18 dBm) atMIC jack adjust VR12 Key TX; adjust for 25 watts PEP.
Sep 12, 2012 | Galaxy Radios DX- 88HL Base CB Radio
How do i find and turn up modulation
If your asking for an internal adjustment,you need to be a qualified technician to do this and the radio's schematics..which I don't know either answer to,so external adjustments would be mic gain knob,you can also gain modulation by lowering the output power knob,both can be adjusted to get the most forward swing by watching your meter swing when am or sideband transmitting.If you are using the stock mike,you could also upgrade to power mic properly wired for your radio.If you are a qualified to do so,there are online sites that have info on upgrading the modulation to this 10 meter radio by adjustments,modifications and add on parts,which does require an amateur license to operate unless modified for cb bands and only transmits on these bands..according to fcc rules.
Aug 14, 2011 | Magnum DeltaForce CB Radio
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the one...
Some mics will require the trim gain to be full on. Check the mic gain by pressing the PFL for each channel and set trim to be below the clipping level with maximum vocal into the mic.
There are some low output mics that may be inadequte as far as output goes. Shure SM58 are industry standard mic... If you don't have one to try, borrow one to test with.
After that, the slider, EQ controls and the MAIN sloder has all the control.
Sep 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Mic output of my pmp3000 is weak,levels must all the way up to get any mic sound louder,Im using balanced xlr's for my mics, Is there any adjustable sensitivity adjustment inside the mixer? like the...
The answer to your question is NO, there is NOT an internal adjustment.
For many mics the trim is used full clockwise. Some higher output mics I use the trims are run at 3 o'clock which is mostly turned up. This is NORMAL for most mixers. If you don't have enough mic gain relative to other inputs, the fault is balancing the other inputs down and using higher setting on your MAIN slider.
If you use 8 ohm speakers then you can expect to get about 200 Watts of audio per side with this amp. You can get about 400 Watts RMS (600 Watts peak) using 4 ohm speakers.
The efficiency of the speakers makes a lot of difference in the sound level output/
How many watts is a tristar 120?
A Tristar CB radio cannot legally exceed 4 watts of transmitting power.
You can add anetnnas in order to increas the "gain" to have the equivalent of much more transmit power.
Microphones aren't measured in watts.
The "impedence" (amount of resistance) is the important measure.
Sep 30, 2009 | Astatic 636L Noise Canceling Microphone...
10 kc drop at key up no transmit
have you changed the voltage regulaor, or check it first 2 outside legs should red your 13 volt middle around 9
Jan 03, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Yaesu FT-890 Technical Manual Logo
76 people viewed this question
Top Yaesu Radio Communications Experts
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
