Question about Epson Stylus CX3200 All-In-One InkJet Printer
Low on ink. don't know how to change ink cartridges.
I lost my printer manual. now i need to change ink cartriges and i don"t know how. can you help me?
thanks----aw
  • mollyw111 Jan 06, 2009
    printer: Epson
    model: cx7400
  • Quickfx PC Repair May 11, 2010
    Can you post the brand and model of printer you have and I can get you your answer.
    President:
  • 846 Answers
Heres a direct link to the download page so you can get a manual, its free. CLICK HERE
That should help you the instructions for changing ink is in there, feel free to give me a Fixya rating if this answers your question.
Posted on Jan 07, 2009
Need tp know how to change cartriges
Refer page 103 onwards in this manual to find out information regarding ink cartridge monitoring and replacement.
https://files.support.epson.com/pdf/xp200_/xp200_ug.pdf
Sep 03, 2014 | Epson Expression XP-200 Inkjet...
I put new ink cartriges in my cannon s400 this morning, it is afternoon now and it will not print in colour, It will not print the test either, it was working before I changed the cartriges, can you please...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 13, 2011 | Office Equipment & Supplies
Replaced cartriges with remanafacuter. Front
Try removing all 4 ink cartridges and unplug the power.
Close the ink cover, leave the ink cartridges out and then plug the power back in.
Once the printer boots up completely, reinstall the cartridges
Mar 26, 2010 | Dell 968w Printer
The other day i opened the cartriges to see the number so i know which ones to get at the store and now i know ink is very low not sure how low but when i try to print it says allign cartriges and it dont...
Hello. Usually, the printer will just notify you that the ink levels of your cartridges are low and if they're out of ink already, it will advise you to replace the cartridges and won't print. In your case, the cartridges may be sending wrong information to the printer. Since the ink levels of your ink cartridges are low already, you might as well replace them. Hope this helps.
Mar 21, 2010 | Lexmark X2600 InkJet Printer
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Jan 16, 2010 | Office Equipment & Supplies
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Need to know how to change ink cartridges, need manual
Both of your answers are at the below link.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=15600#DownloadDetailAct
hope this helps
Apr 13, 2009 | Canon iP3500 Photo Printer
Hp 5150 deskjet says that it is low on color ink
The low ink warning is actually normal for remanufactured cartridges. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. The prints should still be the same quality. You can either press the "Resume" or "OK" button to continue printing, or go into your printer settings and manually disable the ink level indiactor.
Feb 07, 2009 | HP DeskJet 5150 InkJet Printer
Ink cartriges not being recognized by printer
It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
152 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
