Question about Jabra Cell Phones
Jabra s700 activation code - Jabra Cell Phones
Hello. I can't seem to get my phone to "discover" my bluetooth device.... Help?
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT500.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
Sep 05, 2010 | Jabra BT500 Wireless Headset
How to pair jabra bt500v to a blackberry curve
Paring the JABRA head set to Mobile phone
3. Search for Bluetooth devices and select Jabra BT500V.
Thank you
Sep 03, 2010 | Jabra BT500V Wireless Headset
What if i can't find my model phone for instruction to connect to?
Hi
3. Search for Bluetooth devices and select Jabra BT2070.
Thank You
Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
All I can read on my bluetooth is that it is a Jabra. I don't have a user manual, I do have it paired with my phone but I don't know how to turn it off other then go to my tools in my phone and turning it...
You can not turn it off from mobile you need to turn it off using the key on the headset.Press and hold that button for about 4 seconds it will switch off.
To pair the headset follow below instructions
Thank you
Aug 31, 2010 | Jabra BT350 Bluetooth Headset Headset
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
Mar 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
How to use Jabra BT5010 with 2 mobile phones
Be careful of the earhook Jabra does not offer a replacement in the BT5010
Dec 07, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT125 Bluetooth
First u switch off the Jabra Headset..
then switch ON the Bluetooth in ur Cell.
then search for active devices in your cell..
while searching switch ON the bluetooth Headset.press and hold it continuous until the light is on.
you must hold it for approx 15 sec..
then the jabra wil be displayed in your cellphone....
tats it....add it....
enjoy,,
Nov 28, 2007 | Jabra BT125 Headset
Cell Phones Logo
214 people viewed this question
Top Jabra Cell Phones Experts
J.D. Browning
J.D. Browning
ka4iup
ka4iup
Eddie Dalton
Eddie Dalton
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
