Question about Fisher and Paykel AeroSmart DG27CW1 Gas Dryer
I have a Fisher and Paykel dryer DG27CW1. What would cause it to squeek while running and black grease gets on the cloths?
SolutionGuy
  • 331 Answers
SOURCE: Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Posted on Aug 23, 2007
abhishek33
  • 1239 Answers
SOURCE: Fisher Paykel degx1 electric clothes dryer
Thermostats, the dryer temperature control switches, are controlled by the temperature inside the dryer or by the heat of the motor. One or more thermostats on the panel can be adjusted to control the temperature in the dryer. Operating thermostats sometimes stick, causing control problems. These thermostats are usually positioned near the exhaust duct bulkhead or the fan housing of the dryer. Remove the back panel of the dryer to get at them.
Before you make any checks, try tapping the housing of the thermostats lightly with the handle of a screwdriver. This may jar the contacts loose. Temperature control switches are located behind the dryer control panel, and the panel must be removed for switch testing or replacement. Here's how to test and replace the thermostat:
Step 1: To check the control panel thermostat, make sure power is off to the dryer. Test the thermostat with a VOM set to the RX1 scale. Clip one probe of the VOM to each thermostat terminal. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Step 2:
 If necessary, replace the thermostat with a new one of the same type. Connect the new thermostat the same way the old one was connected.
Step 3: To check an operating thermostat, first make absolutely certain that the power to the dryer has been turned off and the dryer is cool. Then disconnect the leads to one side of the thermostat. Test an operating thermostat with a VOM set to the RX1 scale; clip one probe to each terminal of the thermostat. Disconnect the leads to one side of the thermostat so that the meter won't give a false reading. If the meter reads zero, the thermostat is working. If the needle jumps to a high reading, the thermostat is faulty and should be replaced.
Posted on Oct 10, 2008
SOURCE: Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Posted on Dec 16, 2008
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
  • 20 Answers
SOURCE: fisher paykel dryer DE04-US6 just get a buzz sound
Open up the door and push the door switch and hit the start button and try to turn the drum by the baffle in the dryer and it it starts to go then you need a new motor.
Posted on Aug 20, 2009
Testimonial: "Held the door button in...pressed the start button...spun the dryer drum...and it started spinning...i.e. bad motor. nice work thanks"
Aerosmart dg62t27dw2 belt squeeking and making clothes stink
Your belt is not on the pulley correctly. You will likely need to purchase a new belt as the damage has likely been done. Remove back cover and then remove casing (video on youtube) Replace belt. You may be able to fix quicker by flipping dryer on side and replacing the belt from the bottom, but it is a tight fit.
Jan 12, 2014 | Fisher Paykel Fisher & Paykel AeroSmart...
Belt squeeking
Dirt builds up in a dryer over time, belts wear and wheels that the drum rolls on can be worn. Once found a pager in a dryer. There is loose change and pencils and... taking the dryer apart, cleaning and lubricating and replacing the belt are maintenance items that are often ignored. Inconvenient, yes. Dirt is the enemy of mechanical equipment and dryers collect dirt and paper and anything left in pockets of clothes. A vacuuming and general clean and lube helps. Check for free rotation of the drum before and after and make not of the level of resistance with the dryer empty. Some other parts such as the drum wheels may have worn spots. Do it as soon as possible. DIY or a pro. If they let you watch, then you may be able to do some of the lighter work for yourself the next time. Or check out a DIY appliance repair book.
Fisher Paykel Dryer Fault Code 22 Info
That is a fault for the "Door Actuator Open Circuit". You may have not had the door closed completely and when you opened the door to check it out, you closed it completely. Another possibility is the sensor module is going bad.
Feb 10, 2012 | Fisher and Paykel DE27CW1 Electric Dryer
I have a Fisher Paykel dryer that is squeaking badly. Is there a oil/grease port?
There is a drum bearing kit which could have failed or also the belt drive pulleys could be squeeking.
Best to get them replaced.
Can't oil or grease them.
Ash
Sep 11, 2011 | Fisher Dryers
HIGH PITCH SQUEAKING NOISE WHILE DRYER IS RUNNING.
check heatmans blog http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking also make sure the dryer belt is aligned and has tension , often an oversized load will cause belt squeek
Jun 05, 2011 | Fisher and Paykel Dryers
Dryer runs does not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 21, 2011 | Fisher and Paykel AeroSmart DG27CW1 Gas...
There is no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Fisher and Paykel AeroSmart DG27CW1 Gas...
The dryer squeeks when the drying. I have turned the drum manually, and I don't hear the noise, it's only when it is turned on and turning that way.
the belt tensioner pulley has a roller with a bearing in it causing this squeak. greasing the bearing may help or a replacement will work even better
Mar 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Small black streaks on clothes dryer is 3 years old services 2 people average use
Black streaks from the dryer are usually and indication that your belt is fraying and needs to be replaced. The rubber from the belt getting into the drum with the clothes could be causing your issue.
Dec 12, 2009 | Fisher and Paykel DEGX2 Dryer
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
Fisher and Paykel AeroSmart DG27CW1 Gas Dryer Logo
59 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
