Question about Lands Phones
No dial tone on new Philips CE0168 phone - Lands Phones
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
funkyjacob
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
wealthwise
  • 111 Answers
That seems very strange, I can't think of why a phone would screw up your line and dial tone, it may just be a coincidence, the best advice I can give you is to check for voltage on the line, to do this you need a multi-meter and access to the connecting wires on the wall or the line box, short of that sounds like you need a phone tech to take a look at your lines. sorry
Hope this helps.
Posted on Dec 06, 2008
whosale
  • 24 Answers
SOURCE: Phone has a dial tone but will not dial
I would first verify that the line is good. Take a known good corded phone. YES corded phone !!! and try dialing with it and make sure it dials on the line every time. Also make sure that the Pulse/Tone setting is set for your service( there is still a few area without Touch Tone belive it or not)
Once you verify that the line is ok check each phone and take the defective ones back to where you bought them.
Posted on Dec 29, 2008
SOURCE: phone has not dial tone or buttons have no function
my phone rings when someone calls, when i pick up the receiver to answer the phone is dead. i have an old phone i plug in and it works fine. we had a prolong power outage, and was wondering if it might have an effect on the phone.
Posted on Feb 06, 2009
I need to unlock my lg ce0168
This is a 15 or 16 digit number that is normally found on the back of your phone, underneath where battery. If this code is provided then it does seem possible to be able to find the master code, which you can then type in and unlock your phone. How to enter LG CE0168 Unlock Code: 1- Power phone on with non-accepted SIM card 2- Dial 2945#*168# 3- Dial Unlock Code and Press the Dial button or OK 4- Phone should show, code accepted
Aug 01, 2011 | Cell Phones
Will not dial out on landline in the tone mode but
There's something wrong with the base unit that connects to the phone line. It's not sending any audio to the phone line, which would explain why tone dialing doesn't work and people can't hear you. (Pulse dialing doesn't need the audio tones so it will still work.)
I've never run across one doing this before. The problem is almost certainly some electronic failure, and I doubt there's anything you can do other than replacing the thing. If this is still under any warranty it should be up to the manufacturer to repair or replace it. If you got this from VoIP service provider, contact their customer service department.
Feb 03, 2010 | Philips VOIP3212G/37
VOIP321 Engaged Tone & Dialing a number out using Skype
Katasen, You punch in the number and press the Skype button.
Nov 24, 2008 | Philips DECT VOIP-321 cordless telephone
I've got a Philips Faxjet 375 which displays NO LOOP CURRENT when I try to fax anything Any advice?
No dial-tone detected. Plug a regular phone into the wall jack and verify dial-tone.
Make sure you are plugged into the LINE port of the fax machine.
Nov 07, 2008 | Philips Office Equipment & Supplies
Philips CD6451B/37 Cordless phone w/Answering machine-NO BASE FOUND-SEARCHING
Try changing the battery. Try using a new AAA rechargeable battries.
Oct 23, 2008 | Philips CD6451B/05 Phone
The phone will have a dial tone and call out but no sound on phone
Look if the VOIP321 speakers are not muted on your computer.
cheers
Mar 19, 2008 | Philips VOIP3212G/37
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
88 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
