Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Low water flow from kitchen faucet
I have a moen kitchen faucet that initially worked well. For the last several years, the flow from the faucet has been reduced such that it now takes a long time to just get one cup of water. I tried a new faucet and had the same problem. All the other faucets in the house have a normal water flow. Any ideas or solutions that I can try to avoid getting a plumber?
  • 91 Answers
Their is likely rust build up behind the valve connections to the hot and possibly cold water supply lines. Turn the water off to the house relieve the pressure and remove both valves. Once removed use a screwdriver to break up the rust. With a small bucket under both lines turn the water main back on slightly to clear rust. Replace both valves with new ones.
Posted on Aug 27, 2009
    Scholar:
  • 49 Answers
Yes... if you have replaced the faucet once and had this same low water pressure on your new faucet then it probably is not your aerator (screw off piece on the tip of the water spout) which can get clogged whenever the valves are shut off and then back on... before doing anything else check that... your aerator can be cleaned and reassembled but a new one is about a buck.
If the aerator isn't your problem it's definately a water pressure issue related to the valves under your kitchen sink -- and here's what you can try... remove the aerator and take a phillips screw driver and hammer to the valves under your sink... place the tip of the driver on the handle screw on your valve and give it a good whap with the water running... a few good whaps on each valve and your pressure may increase and you'll see all kinds of sediment come out of the valve body and down the drain.
Posted on Sep 03, 2009
  • 332 Answers
Chanfge the shut off valves under the sink,, they have a rubber washer in them and after time they seperate and clog the valve,, this will fix the problem,, good luck make sure you get the compression ones if you have copper water lines if they are plastic you will need the ones for cpvc and the 1 step glue to nstall them
Posted on Jun 23, 2009
Need more water flow on a moen haysfield kitchen faucet
have you tried checking to see if the screen is blocked. I installed one and that was the issue. it should just screw off right where the water comes out.
Mar 14, 2014 | Moen 87877SRS Haysfield Spot Resist One -...
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
Apr 21, 2012 | Moen Plumbing
Why did my moen faucet stop working? I have water flow throughout the house but the flow at the kitchen faucet just suddenly stopped!
Rubber gasket on the water shut off valve under the sink has come off and traveled up into the faucet. It's pretty difficult to get it out. If you have access to an air compressor you may get lucky by taking the faucet completely off the sink and blowing air back from the faucet outlet back into the internal piping to dislodge the rubber piece. If that doesn't work, or you can't use the air compressor method, then it's a trip to the hardware store for a new faucet.
Jan 11, 2010 | Moen 87530 Touch Control Single Handle...
The kitchen sink makes a loud popping noise
Try removing the aerator on the faucet. If that resolves the popping sound, try replacing it with one that allows for a higher flow of water. (Also the existing aerator may be clogged).
Jan 05, 2010 | Moen 87555C Trianna Single Handle Pulldown...
My moen vestage faucet is dropping water pressure. It worked fine when it was installed but the water volume out of the faucet has dropped to less than half of what it was.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Jan 03, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
707 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
