Question about Parker Buck Buster Crossbow
Can I uncock my parker crossbow without shooting it?
After hunting for the day I want to release the cocked bow without shooting an arrow. Is their a way to do this?
Are the refill arrows for the z-curve bow by Zing compatible with a z-tek bow?
Because of the way that the Zing bows are made they are compatible. These bows use hooks on the arrows to shoot so as long as the arrows have those hooks they will work.
Feb 16, 2014 | Zing Toys Air Huntress Z-Curve Bow
Tip
Simple tips on becoming a better archer
a few simple tips you can use for shooting your bow and to improve your arrow grouping . first it starts out with a good stance your feet should be shoulders with apart but not over spread apart.you will want to face 90 degrees to either the left or the right of the target depending on your shooting hand .second your draw ,when you draw your bow the bowstring should sit right below the far outside corner of your eye..thirdly calming your self take a few deep breaths and hold your last breath till your ready to shoot and settle your pins (sights) on your target remember to use the right pin for the right distance.. fourthly remember not to drop the bow when you release the arrow.i dont mean actually dropping the bow on the ground but lowering your extended arm holding the bow forward to quickly before the arrow has time to release .dropping the bow can and will cause your arrows to drop too ...shooting your bow at longer distance will tighten up your arrow grouping at closer distances
on Jul 24, 2012 | Archery
HORTON FURY BOWSRING FRAYING WHERE COCKING SLED ENGAGES IT ONLY SHOT 20 TIMES
Seem to be no fix i have same problem I am scared to shoot it now after 3 snapped strings in a row. Horton is belly up and Ten Point will not fix them after they took Horton over. Mine was brand new and only got to shoot it 10 times before the trouble ...boat anchor now i think.
Oct 08, 2012 | Horton Archery Horton Fury 160 Crossbow...
How fast can an arrow travel?
Recurve bow arrows can travel up to 150 mph. compound bow arrow can travel up to 200 mph and in longbow arrows the velocity is slower because the weight of the arrows.
Aug 26, 2012 | Betsey Johnson Archery
How does a bow work?
A bow is a flexible arc which shoots aerodynamic projectiles called arrows. Essentially, the bow is a form of spring powered by a string. As this string is drawn, energy is stored in the flexible limbs of the bow; the energy is transferred to the arrow when the string is released, projecting it much farther than a weapon could be thrown.
Jul 30, 2012 | Archery
What is good to use for a target in archery?
You can buy archery targets, but they can range anywhere from $40 -$200. If you are looking to make your own, this is a fantastic article to read: Making Archery Targets from Livestrong.com.
  • I've used targets made out of hay bales in the past.
  • You can also make them from feed/grain sacks, packing filling, sand bags or old carpet.
  • The article above will give you instructions on how to make all of the types, then some.
Jul 09, 2012 | Archery
My string broke on my bow and arrow and I wondered what it was made from and could I replace it myself?
In archery, the bow string was originally made with linen or flax fibres, which are individual stings woven onto one. It would be better to take your bow in to have it repaid by a professional as you will need the right tension for the bow to shoot arrows at the correct speed ect.
Cocking sturip for parker cross bows
I have not hunted with my Parker Buckbuster bow since 2010 season. Now I can not **** it. Only can **** about halfway, Cams? String? What happens if not cocked for this long?
Jan 28, 2012 | Parker Buck Buster Crossbow
Early in the games there is a part where you must place an arrow in Eros's bow. The game will not let me pull the bows string back to insert the arrow. It keeps telling me this is what I have to do but...
Best qcups
The following passage was taken from the site: http://www.gamezebo.com/games/cleopatra-riddle-tomb/walkthrough:
"Take the broken arrow (bad luck) or Cretan arrow (good luck). Return to the statue of Eros
without the arrow near the pyramid. Operate the bow and the Sagittarius icon on the pyramid
will extend. If the arrow is broken (bad luck only), open the inventory, disassemble the
broken arrow and then combine the arrow tip, arrow feathers, mended stick and pot of bitumen
to assemble the arrow. Use the arrow on the bow. Operate the bow once and it will move down
to the middle position.
Half turn and push the sign of Sagittarius on the pyramid to make Eros shoot the arrow:
It hits a point on the wall and opens a secret door. Move forward one screen. Examine the
door and then move forward one screen to Akkad's workshop."
Go to this site if you want to read more, or do a Google search using the name of the game and the word "walkthrough" to find multiple sites which could be of help.
Best of luck. From: 11407336.
Sep 06, 2011 | DreamCatcher Interactive Cleopatra Riddle...
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
Parker Buck Buster Crossbow Logo
59 people viewed this question
Top Parker Sport & Outdoor - Others Experts
Bill Eager
Are you a Parker Sport and Outdoor - Other Expert? Answer questions, earn points and help others
