Question about Toshiba 36AF43 36" TV
No remote control on 36af43 toshiba- not the controller
Is it difficult to change the i-r sensor in this tv?
Do you have to remove the whole shell from the set or can one open the front panel to access it?
  • 236 Answers
SOURCE: TV won't respond to remote(s)
I don't know of any adjustments for the IR receiver but the receiver itself could have gone bad or something may be blocking the IR lens not letting the IR signal get through. Maybe (but unusual) there may be a cold solder joint in the IR circuit. Sometimes dust will collect on the inside of the IR lens causing this problem. You can verify the operation of your remotes by holding them close to an AM radio receiver and pushing the buttons. You'll hear a popping sound through the radio speaker whenever a button is pushed. You may have to tune the radio up or down the band to pick up the remote's signal. Stargazer
Posted on Mar 03, 2007
  • 1694 Answers
SOURCE: Toshiba 36inch color tv demo troubleshooting
Demo is activated / de-activated by holding a combination of
two buttons on the tv front for at least four seconds. Try menu &
power or vol up & chan up...........T.
Please rate this solution.......
Posted on Nov 12, 2007
SOURCE: TOSHIBA 36AF43
I'M USING THE CABLE LINE ONLY.
Posted on Feb 14, 2008
  • 15 Answers
SOURCE: How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Posted on Jan 12, 2009
  • 668 Answers
SOURCE: front panel button access
You would be better off replacing all the switches on the front panel with Part # 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this Helps,
Skyassoc
Posted on Jul 02, 2009
TV does not detect remote control.
Remote control receiving sensor circuit problem in the TV. Mostly due to degradation of the sensor over a period of time.
Go close to the TV and see whether you get a response. If it responds try determining the distance back wards. If the remote works up to certain distance, the problem is weak sensor (TV).
If totally not operative it is sensor circuit problem. It could be sensor or it's associated parts.
May 24, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My remote control on my toshiba 32" tv stopped working or would work periodically. I have reprogramed the remote and changed the batteries 3 different times with same result. I purchased a remote ctl from...
A lot of times it is the remote sensor in the set. These are good sets so I would have it checked out. Could be fairly cheap. Thanks for using fixya.
Nov 09, 2009 | Toshiba 32A30 32" TV
Toshiba 36AF43 will not operate via remote control (Yes, the batteries are fresh!)
try unplugging the tv and allow the tv to remain unplugged for a least 5 minutes. This will force a reset on the tv which should resolve your remote issues.
Dec 17, 2007 | Toshiba 36AF43 36" TV
Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Sep 22, 2007 | Toshiba CT-90157 Remote Control
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Toshiba ct-90157
What is the model# you own, for your TV along with yout satellite system box? MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
Can I control my DVD player from this remote and how?
Probably only as long as it's a Toshiba dvd player, can't say i've ever got one to work even the TV hansets with dvd controls. This is what the site says it works with:- This replacement remote will operate all functions of models 32A33, 32A43, 32AF43, 32AF44, 35AF44, 35A44, 36A43 and 36AF43.
Dec 21, 2006 | Toshiba CT-90157 Remote Control
Toshiba 36AF43 36" TV Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
