The freezer is ice cold my lower dept. is about 80 degrees
Hello - If I may suggest, as it is a Top Mount; there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means the unit may have a faulty compressor or a sealed system leak. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
SOURCE: Sub-Zero 550 with Bottom Freezer
The life expectancy of these is as long as you want to fix em. I stll work on plenty of them builty before 1980. You may have to pay $900 for a bad compressor, but the fridge replacment cost is around $600, so it's up to you. take the back wall off behind the shelves an look at the coils. If the coils are frosty on only part of the coils (less than 2/3 I would say) Then you have a freon leak. likely from the evaporater (this will need to be cut out and soldered in with aq torch) If you have all frost top to bottom, defrost it, turn down the setting, and check that your door seals well and the door doesnt bounce open when you swing it shut. If there is no frost at all, feel the frame around the door opening. If its warm, take of the upper grille and then the upper sheild on the left side (2 screws). Use a flashlight to shine trough the condenser (thing on the right, looks luike a radiator) if you shine a light throuhgh towards the fan, but cannot see the light come through on the fan side, you need to vacuum off the condenser and try again. If light still does not get through, go to your local auto parts store and buy 2 cans of NON FLAMMABLE brake cleaner. Unplug the unit and hose the condenser down with the stuff untuill you can see light through it from the flashlight. this will be messy, so have a spare rol of paper towels handy. The fumes will be bad too so open a window and put a fan in if you can. If the frame of the fridge is not warm, and there is no frst, discannect the cold controll and use a piece of wire to connect the two wires together after you disconnect them from the cold control. Do not connect the green wire, and be carefull as ther will be 110volts in one of those 2 wires if you didnt unplug the fridge. let the thing run with the control bypassed for 15 minute or so and watch the coils to see if they frost. If they frost all the way, top to bottom, replace the cold control (one for the fridge on the right, by the way)Hope you can get the info you need out of this. Good Luck!
SOURCE: Frigidaire frs24zrh refrigerator not cool enough
Check out partselect.com. need to replace defrost timer and defrost thermostat. good luck.
SOURCE: frigidaire side by side freezer not freezing but
you may have defrost problem check see if you have frost build up in the freezer back wall
SOURCE: freezer is cold but refrigerator isn't
Number one when you can always provide model number and make...it helps
enormously in troubleshooting otherwise you get these long detailed
threads...from an anal tech like myself.
Cold is a relative term....how cold...use a thermometer...and determine
if the freezer...is at least..10-20 degrees or colder if not it is not
cold enough...and here are some generic answers for that problem....I
will list at the bottom of this thread...if it is
A. You will need to determine if you are getting air flow into the
refrigerator side compartment..there is usually a baffle...that
controls...the amount of air-flow into the frig side...it can be
adjusted...if not it could be broken or have come loose...it is rare...
B. Is something blocking the baffle...as in food ...groceries...
C. The thermostat could be out of adjustment...and or going bad...(how old is the frig)..
D. Some newer units have a dual fan system..(but rare)..if the frig side fan is out...this could be the problem...
There are several reasons this can be happening...
1. The seal
on the door may have a tear or may not be seating properly...this
allows excess warm air into the freezer compartment and in its effort
to remove the same ...frost appears.
2. There is something call
a thermistor (which senses temp and ice build up) that is cycled on and off as needed to remove excess frost
accumulation and or ice buildup on the evaporator (freezer) coils...it
is a heat strip which actually defrost the frost/ice. If this is not
working frost will accumulate and eventually it will become
Ice......now the remarkable thing about Ice accumulation is that you
would think everything would remain cold or get colder ..however in
this case the opposite occurs...it insulates the coils and thereby
increasing the temperature...put a thermometer...one that is calibrated
properly...(calibration can be set by placing a thermometer into a
glass of ice water...the temp of a glass of ice water..after a few
minutes setting will be exactly 32 degrees)..if the temperature of your
refrigerator is gradually rising over the period of a week...you will
need to call a tech or replace the thermistor and or trouble shoot
other problems that may have occur such as..
3. The evaporator fan
may be going out although they usually make a high pitched whining
noise of a whirring noise before they go out...not always and if they
are intermittently cycling off then frost would build up...do you
always here a fan running when you open the freezer and hold the button in above the door..(fan switch)...if so that is
good...fan is working...but it may be cycling off at times when no one
is aware.
P.S.
the odds of it being due to overfilling are slim...I have been in the
industry for 35 years and that is what freezers do...which a lot of
people don't realize is that freezers don't actually cool anything
..they just remove heat and when you remove all the heat all that is
left is cold (like in space) and when heat is removed quickly frost can
appear like when you blow your breath on a freezing cold window..then
right your name....but I digress...any way..if there was an excess of
heat due to a lot of new food in the freezer it would correct itself by
one of the processes i mentioned above..and it would never result in
Ice..you probably have one or more of the problems I
mentioned...evaluate how long its been going on...
4. Thermostat could be out of adjustment..and or not functioning
properly..which
would delay or inhibit a defrost cycle..from occurring..unfortunately
almost all of these problems require a tech...or a good handyman.
This should lead you in the
right direction...if you need help in finding a reputable service
company in your area let us know..I hope this has been helpful..if so
PLEASE rate me....thank you... .......The Fang
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
heatman101
