Question about iLO Televison & Video
MY TV SOUND IS AT FULL BLAST AND CAN'T LOWER-ANSWER ??
    Top Expert:
  • iLO Master
  • 14,553 Answers
Usually it is a issue with the tiny switches under the control buttons on the set---ie the vol up (not the plastic button) switch is bad.
Keyboard issues and answers: A problem that is more common than most people think is an issue with buttons on the control keyboards of modern TV sets. Recently for whatever reason I have seen more questions about this so I have composed this answer and solution for these kinds of problems. It can be any button on the set-channel up/down or volume up down-you name it. The symptoms are the same: channel will scan up or down and will not stop-remote control has no effect on this---It can be channel, volume, or even input or menu if the set has those up front or on the side of the set. All these push controls have something in common-beneath each is a tiny momentary push switch-when pushed with the plastic button it performs a specific task (vol up or down etc.). What happens is the afflicted switch beneath the plastic button is bad-when released it is supposed to stop its function but does not. Keyboard or button controlled features have PRIORITY over the remote control, hence the remote will not stop this from happening. Both the remote and the keyboard go to the microprocessor in the se t but the keyboard is first in line. How to resolve this issue? Someone needs to get at the tiny pc board with the buttons and locate the one associated with the issue (ie sound or channel etc) and unsolder that switch from the board-usually just two pins (may be more for mounting only purposes) and then see if set does not have the issue with switch out of the circuit. For the TECH minded with the board out test here the switches with a ohm meter set to high resistance-any reading with button not pressed means a bad switch-seen ones that read 5,000 plus ohms-it may be necessary to unsolder more than one switch to locate the offender here but an open reading with switch not pressed is the rule. I have taken the time to compose this answer as some do not understand what is happening in these types of situations---No magic wand or smoke and mirrors here-have to disable the offending switch to know. The beauty (in my view) of this kind of problem is if found, you really do not have to replace any part-just operate the set with the remote with one button that no longer functions on the set itself-who could ask for more?
Posted on Nov 05, 2012
Sharp aquos flat tv sound can not be control with remote, remote okay
I am not certain what you mean by remote is OK but the way remotes work with TV sets and cable boxes is that the remote sends channel info to the cable box and sound control to the TV set. Is the sound on full blast? Some cable boxes allow you to adjust the sound too. Without more information it is difficult to know where you are having a problem.
Jul 04, 2017 | Sharp Televison & Video
My subs are skipping notes and only play low notes decently and only play when the volume is at full blast. The amp wiring is fine and the radio wiring seems alright. No idea why it is
First of all the bass needs to be tuned down on stereo you shouldn't need to turn volume fill blast then you set your amp so your subs sound good hope you have a cross over. Never tune the gain on your amp past 3/4 ether play with you air flow to that some times works I found that if you do this your bass gets louder less risk blow
Mar 02, 2013 | Car Audio & Video
Blown? all sound is distorted. Upon exiting the auto speaker calibration mode, I hit the video input from my tv and got a BLAST of static, volume set itself to 54... now everything is distorted. speakers...
No product information being given for either the (amp?) or the TV we can only guess. You should look at the manuals first to make sure your TV's audio isn't a digital bitstream fed into an analog input.
Bad fuse?? A blown fuse will result in silence.
May 26, 2011 | Audio Players & Recorders
My LG plasma TV suddenly no video outing out from the screen but audio is fine. what do think the problem
The most common fault is either the PSU, which causes no sound generally too, and the Y-Sustain and Lower Buffer.
More information needed for a more accurate answer.
Y-Sustain & Lower Buffer.
The TV Model Number would help greatly, if it is a bit newer LG do a repair kit of the 3 main boards inside the TV.
Sep 06, 2009 | Televison & Video
Can't turn volume down!
Go into your sound devices from the control panel. You should be able to raise & lower the volume from there as well as putting the volume icon back into your system tray. Hope this helps.
Jul 08, 2009 | Compaq Armada E500 Notebook
"Push Power'' and ''Protector"
my sony bravia is KLV-32S400A. i tried to stop the dvd playing and turn off the home theatre, but the tv is still on. suddenly there was a loud blast sound and the home theatre shows PUSH POWER PROTECTOR.
please help what should i do with it?
May 13, 2009 | Sony DAV-HDX500 System
We are having trouble witholumne play back wheen tv is up full blast and
check cables get new ones. and check the DVD volume is up
Apr 13, 2009 | Televison & Video
EMac sound will randomly go to FULL BLAST
If you don't get it fixed, try hooking up external speakers. The external speakers have a hardware switch that prevents it completely from going to the built-in speakers.
Jan 27, 2009 | Apple eMac G4 Desktop
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
