Question about Garden
How do you change the oil on a 158cc troy bilt edger?
  • 7 Answers
SOURCE: troy-bilt gas edger trencher won't start. Spark
Remove spark plug and pour 5mls or one teaspoon of premixed gas in the engine. Depress trottle to full with choke on "run", pull starter about 10 to 12 times If it starts and run for a while and then shuts off your carb needs servicing. If not remove muffler and look for a spark arrestor screen. This could be plugged up with soot. If it is, replace and this would have been your problem. While the muffler is off slowly pull starter rope and examine the piston if gas and oil oozes backwards as the piston moves to the top then the piston and rings need replacing.
Posted on Nov 10, 2009
  • 242 Answers
SOURCE: starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Posted on Dec 28, 2009
rycgl
  • 1545 Answers
SOURCE: Recieved a Troy-Bilt Edger 4 cycle from a friend
First off, make sure the amount of oil is correct NOW. Does it start or try to? Check for oil in the air filter...if so clean or replace. Check for oil on the spark plug...if so, clean or replace. Start with the basic fixes and work your way up to the more complicated repairs
If too much oil is still in the machine,,,drain it out till it is at correct level. Do not think the engine will just burn the excess off....this can damage the engine.
Posted on Aug 08, 2010
mwoodring1
  • 496 Answers
SOURCE: how to replace belt on troy bilt edger model
can you send me the Serial Number and i can get you the manual on pdf file for you to download free.
M.Woodring
Posted on May 29, 2011
canwoodjc
  • 3301 Answers
SOURCE: how often should I change the oil in my Troy Bilt
every 30 hours of use, and 5w-30 is fine
Posted on Jul 14, 2011
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
TROY-BILT TB525 EC 4-cycle Gas Trimmer+how to fix oil leak
Oil runs back out of the carburetor air filter intake if I fill to oil level indicator on no oil gas mix engine. Anything wrong or am I just over filling the oil?
Jun 28, 2012 | Troy-Bilt Garden
Troy-bilt TB525ET 4 cycle??
no you do not mix gas but there is a type of oil that goes in the back of your engine called the houle and im not sure if its 4 meaning regular oil or 2cycle im thinking its 2 because as the engine runs it mixes on its own to create a so called 4 cycle which to everone ive talked to on the outside is a week engine im being told that 2cycle engine has alot more tourque if you want to get a job done quick and it look good
Feb 21, 2012 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Nov 23, 2011 | Mtd Garden
I have a troy bilt string weed cutter 27cc TB21Ec and need to know the oil gas ratio. I just read that it takes straight gas but my cap on the weed cutter where you put the gas says gas/oil mixture
Don't know that exact trimmer, but I always run 40:1 in all my trimmers, chainsaws, etc. That is 3.2 oz. of 2 cycle oil to one gallon of gasoline. I rebuild these machines daily and run that mix in everyting, except when it's actually specified on the machine.
Aug 11, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
What kind of oil goes in crankcase
Rule of thumb for lawn and garden equipment ...
If it is 2 cycle - gas and oil are mixed - 50 to 1 mix. Some two cycle engines require more oil ... up to 32 to one.
It if is 4 cycle - has a fuel tank and a crank case - 30 weight oil SJ or better service rating.
If you want to become an expert on oil ... go here: http://www.bsehome.net/pdf/OIL_S_EG.PDF
And a final word ... it is always good to refer to the manufacturer recommendations when selecting lubricants. Troy Bilt (no longer manufactured by the Troy Bilt Company in Troy New York) uses a number of different engines on their procducts. Here is a link for you: http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54971_54970_54970_-1?cm_mmc=Google-_-WG-_-Tillers-_-Sponsored
Thanks for using FixYa.com
Mar 22, 2011 | Troy Bilt Tiller/Edger 26cc, Model No....
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Changing oil
is the drain plug on a troy bilt 6.5 hp ontop of the blade in the right hand cornor
Apr 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
