Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio WTW6200VWO STUCK IN ADD GARMENT MODE
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: i need a manuel for my whirlpool caprio washer
If an owner's manual is what you need, go to managemyhome.com and enter your model number under the "Manuals" link. Your owner's manual is available in .pdf (Adobe) format that you can download or print for FREE.
NOTE: The last digit of your model number is a zero "0", not the letter "O".
If a repair manual is what you need, the part number is 8178583. It can be purchased at either pcappliancerepair.com or appliancepartspros.com for less than $10.
I hope this helps you.
Posted on Nov 05, 2009
  • 84 Answers
SOURCE: HIT PAUSE CANCEL BUTTON TO ADD A GARMENT AND IT IS
unplug the machine wait 5 minutes and plug back in the board should go back to normal adding a garnment should be done on the washing not on the rince
Posted on Sep 12, 2010
the_admiral6
  • 14 Answers
SOURCE: The doo rof my HE
Unplug washer and remove lower front panel by removing 3 screws on bottom of panel. You will need "torx" or nutdriver. Reach in and up on right side of inside of washer, right were the door latch is, at the bottom of the mechanism is a manual release. Pull downward on the release and the door should open.
Posted on Dec 31, 2010
ercupa190
  • 12223 Answers
SOURCE: whirlpool washer constantly has a "add a garment " light on and wont spin
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace.
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Posted on Sep 27, 2012
My whirlpool cabrio washer wtw6200vwo shows f71code and wont spin out clothes
WHIRLPOOL CABRIO WASHER ERROR F71. The Cabrio Washer Error F71 code is the same as the SD code: This error means the main control board detects too much drag on the basket during the spin cycle.Mar 29, 2017
Nov 13, 2017 | Whirlpool Washing Machines
Whirlpool cabrio wtw6200vwo will spin if i help itget started otherwise not
have an electrician check the start / run capacitor for the motor
it appears to be low in capacitance ( failing) and will not give the correct voltage surge to spin the motor properly
check the program board
Sep 23, 2015 | Whirlpool Washing Machines
How do I dye in my washer
You put the water into the machine, then add the dye to the water after it is filled up, use the hottest water you can use for your fabric. Let it agitate for a minute or two, then add the garment. Let it finish the wash cycle and it will be dyed. You can also dye things on top of the stove. Heat a pot of water, add dye, place garment into the dye and let it sit in the water for about 20 minutes then take it out and rinse in cold water.
Note: hot water will make your garments shrink, so be careful
Feb 25, 2015 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool washer is stuck on lock mode add a garment
Hello, j2sonke. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Jul 03, 2014 | Kenmore 42822 Front Load Washer
Water will not fill my washing machine and the add garment light is always on
Your water inlet valve (solenoid) is bad and needs replacing. There may be two; one for hot and cold. Either buy both and replace or mess around by trial and error to find the one! Get Both!
Jan 19, 2014 | Whirlpool Cabrio WTW5600XW Top Load Washer
I need a manuel for my whirlpool caprio washer It is model no.WTW6200VWO
Nov 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
