Question about Minolta EP4000/5000 CS/PRO Copier
Copier Minolts ep4050 error code c0601 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 6,696 Answers
Scanner fault. The bright lite under the big glass. Does it come on To reset. Open the front door to your left a small access plate one bolt. remove the cover press trouble reset.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 08, 2015
5 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Posted on Mar 26, 2009
Cogz
  • 1326 Answers
SOURCE: I've got a Minolta model #4050
Yes, it means that something is wrong with the scanner. It may be fixed, it depends what is wrong with it. Is the scanner skewed under the copyboard glass? If so that means that the scanner cables have poped off and they will need to be restrung. It could also be the scanner drive motor or the driver PCB. It may also be that the scanner HP sensor is dirty or is not working correctly. I have worked on these models for years and most of the time it has been a sensor or the cables poped off. There is a jig that makes it easier to restring the cables, but either way it will take time and time is money.... Question is are you willing to put the money in to it?? This model came out around 1995 or so... Good Luck
Posted on Apr 16, 2009
goalie39
  • 469 Answers
SOURCE: error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
RommelF
  • 11 Answers
SOURCE: We have a Minolta EP4050 with an error code C004.
Yes you need to call service this indicates problem in your fusing unit. A busted Heat lamp is the reason or broken thermistor.
Posted on Jan 13, 2010
Error cod c0601
Code C0601 is a problem on scanner, based on my experience, this code comes when the scanner doesn't reach its home position. First try to clear the code opening and closing the front door. If the code still appearing, check for scanner home position sensor, clean it or change it.
Mar 08, 2014 | Minolta Office Equipment & Supplies
Error code C0601 Error code C0072
for the 0072 try this:
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it damage you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
As for the 0600 code the scanner the bright lite under the big glass is not lighting replace the lamp and board
as for the
Dec 16, 2010 | Minolta DiALTA Di183 Copier
How to resolve erorr code c0100 minolta cspro ep4050? spdhandri@yahoo.co.id
ckeck the main motor but try reset first the error to reset that error open the front door then at the left side of the machine you will see the small square attach with 1 screw remove that screw then the plastic square type then you will see the reset botton just press that botton
Dec 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta EP4050 access code
admin or service?????
Sep 14, 2010 | Minolta EP4000/5000 CS/PRO Copier
We have a Minolta EP4050 with an error code C004. Do we need to get serviced?
Jan 07, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta EP-5050 with a C0601 code. Do you know a solution for this code??
Your problrm in the sorter unit.Please check the sensors and the motors.Disconected the sorter unit and work without.
Nov 17, 2009 | Minolta EP4000/5000 CS/PRO Copier
Turn on get error c0500 on a minolta ep4050
the error codes means Low fuser temperature during warm-up
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Jul 06, 2009 | Office Equipment & Supplies
Mar 25, 2009 | Minolta EP4000/5000 CS/PRO Copier
89 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
