Question about Hitachi Gst Hitachi L40A105 40" Class LCD Flat Panel HDTV
There is a running strip on bottom that keeps popping up, HDMI then Dolby Digital then DBC then HDMI then eco something on my Hitachi L40A105A
We were trying to fix the closed caption and ended up with a strip on the bottom which keeps showing status of above, kind of like popping up across the screen. What menu item takes this off?
Howw do I get rid of the panel that runs across the bottom of the screen describing the features without the remote? Dolby, sleep timer, backlight contrast, HDMI, eco
Hi without a remote u can't press exit button ?? Try leaving power turned on & switch power of at the wall for 5 or ten minutes it might lose its memory. God luck.
Dec 10, 2015 | Televison & Video
Hitachi L40A105A is stuck on demo mode...list of its features flashes across bottom of screen...how do i get this to go away
After searching for an hour or so I finally came across this answer that worked for the L40A105A
To answer your question;
First you must set your tv`s input to TV
Then open your menu and go to setup and open it
You will see "auto setup" open it and you will see "e-pop demo" turn it off .
Apr 14, 2013 | Televison & Video
How do i connect my pc with only a vga cable to my hitachi tv (model #l40a105a)?
You can buy a vga to hdmi cable from monoprice.com Although this will only do video. VGA is video only, HDMI supports audio and video. You could, in conjuction get a 3.5 headphone jack to RCA or composite on the same site for sound. Both cables are pretty cheap.
Dec 02, 2012 | Computers & Internet
When plugged in i smell something burning and no picture or sound
Don,t keep on trying it, It could start on fire.It was (Damaged) Buy what is called a (Power) Surge,It can not be (Repaired) in that (Circumstance) they are ususally beyond (Repair)
Oct 24, 2012 | JVC 47" 1080p LCD HDTV - BlackCrystal 4...
I have the 40in hitachi lcd tv and somehow my son has hit something on the remote so i keep getting a pop up on the bottom of my screen that kind of looks like a tool bar but its not it says like hdmi,...
Do a factory reset to this set. Refer its user manual for details.
Just unplug the TV from AC mains wall socket, and re-plug it after 10 minutes or so. This must make your TV a hard reset. Do this first. If it do not help you, make a factory reset. The user manual will have all details about how to do this.
Jul 08, 2012 | Televison & Video
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
May 10, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Vizio SV470XVT will not output Dolby 5.1 from optical out..
TV's only will output 5.1 from HD stations. If you have a DVD player, XBOX 360, etc connected through HDMI, then the TV will only send stereo PCM through the optical out.
Jun 17, 2009 | Vizio SV470XVT 47 in. LCD TV
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
Hitachi Gst Hitachi L40A105 40" Class LCD Flat Panel HDTV Logo
24 people viewed this question
Top Hitachi Gst Televison & Video Experts
slammit
 Mikey
Mikey
ray gallant
Are you a Hitachi Gst Televison and Video Expert? Answer questions, earn points and help others
