Yamaha amplifier m-85 1986 that plays much louder out of right channel than left. have to trun right gain control way down to match left and turn receiver volume way up causing out of balance sound.
  • 1 more comment
  • mandjlunebur Jan 04, 2009
    this is a power amplifier that requires a pre-amp which is a yamaha rxv1800
    when connecting same speaker wires to rxv1800 sound is normal. level meters on m-85 show right channel much higher than left must turn gain on right channel almost all the way down to match left.
  • mandjlunebur Jan 05, 2009
    there is nothing wrong with the speakers they work normaly when receiver power is utilized
  • 19,396 Answers
Testing an amp is quite complicate, you need to have strong electronic background, and to use an oscilloscope and a multimeter in the right way.
Start ensuring that it is not the pre amp. By testing the amp on a different input.
If the amp has same problems on all inputs, then , rather than the balance knob, you have a defective Amp power transistor, in the final part of the amp (near to the speakers output on internal board).
The transistor must be replaced, as it is generating less power than it is supposed two.
You get problem only on one channel just because separate channels have separate transistors aplifying the signal.
Yamaha M-85 user Manual
Posted on Jan 09, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
There are buttons for the setting of the speakers. the look like to rectangles (thin) side by side that say A and B
Posted on Jan 08, 2009
  • 66 Answers
If you have not tried this yet. switch left and right speakers. If problem is still on the right side, your final drive is failing. You'll need to have the unit repaired. If the problem changes to the left side, you've got a speaker issue. Good Luck
Posted on Jan 06, 2009
  • 4,806 Answers
Hi there
The reason that the sound is not equalized is that there is a dry joint either on the output board or the speaker input board.
I have a amplifier that did the same thing and all i did was re-solder the output and input channels and that sorted it for me.
I hope this works for you too.
Good luck and kind regards
    President:
  • 1,990 Answers
I researched this a Bit since you were here last. Everyone that I found though took it in to an Authorized Service Center and had it Repaired.
Posted on Jan 05, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a number of possibilities/ideas you may want to consider/explore:
  • signal source - it maybe that the tapedeck, CD player or whatever is being used as the audio source is the issue. Switch positions of the RCA connectors at the output of the signal source. If the imbalance changes sides, then it is the signal source;
  • preamp - Switch positions of the RCA connectors at the output of the preamp. If the imbalance changes sides, then it is the pre-amp;
  • amplifier - Switch positions of the RCA connectors at the input of the amplifier. If the imbalance changes sides, then it is not the amplifier;
  • speakers - Switch speaker wires left to right, right to left. If imbalance changes sides, then it is speaker or speaker wire. If still the same, then it is the amplifier;
  • of course the RCA/cables could also affect
  • welcomejee has actually mentioned possibility of the volume control if still uses the rotary type. A spray of electronic contact could be a temporary workaround.
Good luck and Thank you for using FixYa.
Posted on Jan 04, 2009
  • Louie  Role
    Louie Role Jan 06, 2009
    There were a couple of checks above, any updates on the results?
    Brigadier General:
  • 8,619 Answers
Hi
I believe the transistor of your right side speaker is burned or is damaged please check. If this is not the case then you need to increase the value of resistor which is attached next to the transistor .
Thankyou
  • 599 Answers
Wires to speakers need to be of same gauge and of same length..and connections clean..switch wires to test at amp if conditions switch.. and advise ..good luck
  • 10,594 Answers
Does this amp has rotating volume control?
  • Shahid Electronics
    Shahid Electronics Jan 04, 2009
    right, its an older power amplifier.
    It has push selectors on front panel and in my opiion needs to be cleaned as contacts of selector switches are rusty / clogged.
    Please unplug amp from Ac outlet, take off top-cover of amp and spray WD-40 in all selector switches including its left-right level controls.
    This will resolve unbalanced level issue in this amp.
Yamaha AX700 amp distorts R channel - sound suddenly louder from R LS and distorted or metallic. Swapped LS L to R to eliminate
1) Check speaker polarity carefully
2) Ensure that speakers are securely connected.
3) Check your Balance control
4) Check your inputs (change inputs L/R)
If that does not alter or fix the problem your right channel may have developed an internal fault. Repair or have it repaired.
Have Fun
Sep 03, 2016 | Yamaha Audio Players & Recorders
Speakers cutting in and out at high volume
The amp is going into protect on the two channels powering the speakers. Turn down the gain on those two channels. You also may want to consider crossing over the speakers a little higher than they are now.
The rating on those speakers are way too high. 6.5's and 6x9's will take 50-100 clean watts tops before they start to break up.
The best solution to get it perfect is....unplug the subs. Turn the gain on the speaker channels all the way down. Then turn up the deck 80% as high as it will go. Play a song. Then increase the gain on the amp until the speakers are as load as they go without distortion. Shut off the car, replugg in the subs and do the same thing. Gain on sub channels all the way down, deck then to 80%, find a bass heavy song, then turn gain up until subs become distorted. If you do this procedure your speakers and subs will be "gain matched" to the proper levels.
Good Luck
Dec 07, 2013 | Kicker IX500.4 4-Channel 500 Watt Car...
How to wire to factory 1999 jeep grand cheerokee
Locate the wires running from the head-unit or factory amplifier to the speakers. In some cases you will find these wires behind the head unit, but it may be easier to go directly to the speakers.
Once the speaker wires are found, use the wire strippers to remove 1 inch of insulation from each one. Attach the left channel of the L.O.C. to the left speaker, and the right channel to the right speaker.
Solder the L.O.C. wires to the speaker wires and seal the connection with heat shrink or electrical tape. Secure the L.O.C. to the vehicle. Plug in some RCA cables to the L.O.C. and run them to the amplifier.
Adjust the amplifiers' gain levels to a medium setting. Turn on the stereo and adjust the volume to a comfortable listening level. Use a small screwdriver to adjust the gains on the L.O.C. up until distortion is heard, then turn the gain down until it goes away.
Turn the volume up on the head unit and make sure that there is no distortion present in the amplifier. If distortion is heard, adjust the gain on the amplifier and L.O.C. accordingly.
Jun 03, 2010 | Stinger Adjustable Line Output Convertor...
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
Car subwoofer wont play loud
You blew up a channel in your amp. Being that it's a Pioneer amp, I would throw it away and get another.
Sep 08, 2009 | Car Audio & Video
Problem with Yamaha Amplifier 361
volume levels on all channels varies depending on what dsp mode you are using. to be able to determine the level you desire, just chnge the level setting of those channels. either you do it by remote control or the front panel of the amp. try setting the dsp mode on disco and you should hear higher vol levels on all channels. Do not expect as well all channels to produce same vol levels as your effects speakers may not be able handle higher power levels.
Aug 12, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Scratching sound in speaker conected to left channel
invert the speaker cables if the problem went to right speaker you will find a problem in your left speaker(cable or speaker)-if not you will have a problem in your amp itself.
Jul 06, 2008 | Behringer Audio Players & Recorders
Very low sound in main left chennel.
disconnect the cabel of left channel from your amp disconnect the cabel of right channel and put it in place of left channel if the problem goen your problem is in left speaker itself (cabel or speaker).if the problem excit the problem will be in amplifier output stage
Jan 28, 2008 | Yamaha DSP-AX1 10-Channel Amplifier
51 people viewed this question
 Grubhead
Grubhead
