Question about Milwaukee Tool Milwaukee 18V 1/2 In Hammer Drill Kit 0627 24
My drill slips under high torque
It sounds like the clutch is slipping
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Posted on Nov 21, 2012
My Dewalt DC925 works well but the torque settings don't seem to be working.when i am drilling screws the drill will just drill until i release the trigger.is this a clutch problem?. Many thanks.
Try to put it on the lowest torque and if it slips when wanted, then add a little more torque and check to make sure it slips. Continue at each torque setting and usually works again at full torque. Usually happens when left on the same torque all the time. This kind of resets it.
May 07, 2015 | Dewalt Drills
Dewalt 771 slips in all torque settings in low, but works in high setting
The clutch is defective , you can get replacement parts from dewalt. There are several dewalt service centers in the US
Nov 03, 2014 | Dewalt Tools & Hardware - Others
Gears slipping
Many of these have a torque clutch that is used in screwdriver mode that will slip when a certain torque is reached as set by the ring around the chuck area. If you want it to not slip, usually you set it on a symbol that looks like a twist drill.
Feb 01, 2012 | Hitachi DS18DFL 18V 1.5Ah Lithium Ion...
The clutch is slipping how do i fix
If its clutching out in drill mode the clutch pin is worn. This part is 635718-00 its only a couple bucks. not hard to repair either bout 5 min.
Sep 07, 2011 | Dewalt DC988kar XRP 3 - speed 1/2" 18v...
What code po741
P0741 "Torque Converter Clutch Solenoid stuck off"
If the PCM detects high torque converter slip when the TCC is commanded ON, then DTC P0741 sets. The Powertrain Control Module (PCM) controls the Torque Converter Clutch Solenoid Valve (TCC Sol. Valve) Pulse Width Modulation (PWM). The solenoid controls the hydraulic fluid for TCC apply and release. When the TCC is applied, the engine is coupled directly to the transmission through the TCC. The TCC slip speed should be near 0.
Thank you for using Fixya and good luck
Aug 05, 2010 | Hyundai Santa Fe Cars & Trucks
Moderrate resistance stops the drill from driving and to scream
The grinding you're hearing is the normal sound for the clutch. There's a ring with numbers on it the higer the setting the more torque it'll take for the clutch to slip. Many of the newer drill & drivers have a drill setting at the high end of the clutch settings others have a separate drill & driver setting. This site will give you most everything you need.
http://www2.panasonic.com/consumer-electronics/support/Building-Products/Cordless-Tools/Drill-Drivers/model.EY7542LN2L
May 30, 2010 | Panasonic EY7542LN2L 14.4 Volt Li-ion...
Makita 6349DWDE 18V Cordless Clutch
could be the clutch needs replaced, but I would check to make sure the high/low switch is fully engaged. Inside the clutch there is ring gear that could have the teeth rounded off I would go to Makitatools.com and type in your model number for a breakdown so you can see what you are getting into, they are not that hard if you are mechanically inclined and just watch how you do it.
Sep 23, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
My Craftsman 19.2 drill's adjustable torque clutch want allow drilling in forward gear.
Try with the drill chuck torque setting set to max. If no joy on that one, work tha low/high speed switch several times. If no luck there, you may need to open the drill and check for a loose linkage, or that something has slipped out of place. It's not difficult.
Regards, --W/D--
Jul 17, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
Dewalt 18V XRP Clutch Slipping
it very economical to repair the drill. replace the transmission.
Apr 27, 2008 | Dewalt 18 Volt Compact Drill Kit
Milwaukee Tool Milwaukee 18V 1/2 In Hammer Drill Kit 0627 24 Logo
288 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
Harjeet Singh
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
