Question about Sony KP-46WT510 46" Rear Projection HDTV
There is ghosting, color is distorted, tried flash focus,
Tried using the flash focus with no luck. It comes on for a second then turns off. When looking at the convergence screen all the colored xs are separate with no white ones.
Http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/?page=3
I had the same problem and cost me $340.00 to fix. Parts were about $20.00 for each, wish I saw this befor
Posted on Jan 15, 2009
When i turn on the tv there is no sound only clicking sound and no picture. then it atomaticly turns off. also the lamp light flashing red? not sure what is wrong.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2010 | Panasonic PT-52LCX65 44" HDTV
Lookslike the picture is in 3d and when i try ti use magic focus
  • Screen looks 3D
Jun 02, 2010 | Hitachi 57F500 57" Rear Projection...
Lost focus.looks 3d. red double. cant focus on red convergence.
This is a very common failure on Projection TV2_bing.gif sets.
  • Screen looks 3D
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
47a7bc4.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing or you can call in a pro.
If you want to do the repair yourself check the site www.TvRepairKits.com.
Their kits include a step by step instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Problem #2 CRT Fluid is Cloudy
Projection tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around video.
Pic of a set that needs the fluid changed. Notice how dull the colors are and how white the screen looks. The screen may also look red, orange, dull, etc.
TV set after fluid change. Notice how bright the colors are now. Everthing looks crisp and sharp again.
724bcba.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant,step by step instructions, etc.
Jan 28, 2010 | Philips Magnavox 51MP392H Rear Projection...
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Tv out of focus
  • Screen looks 3D
Aug 03, 2009 | Akai PT4298HD Rear Projection Television
Sony TV losing focus
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 17, 2009 | Sony KP-65WV600 65" Rear Projection...
Colors dont line up and green is "dancing" all over screen
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
May 15, 2009 | Sony KP-57WS500 57" Rear Projection...
Akai
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 31, 2009 | Akai PT4298HD Rear Projection Television
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony KP-61V90 61 in. Rear... Problem
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jun 18, 2008 | Sony KP-61V90 61" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
