I had a little fender-bender. Rear-ended an Acadian when they stopped suddenly going through a light. Thought the radiator was the only internal problem. Got all the outside parts replaced and the new radiator in only to discover an oil leak that wasn't noticeable post-accident. Apparently something got shifted around to cause the leak. Any ideas? Trying to find the oil filter to check it without pulling motor...
Oil filter Is a suspect actually... any oil cooler lines going towards the front front of oil pan etc... lift vehicle and look ccareful at all areas near damaged area ...good luck
not usually... oil pump...or crank bearings (maybe end of crank got hit and jacked up thrust bearing and/or bearings causing low oil pressure are main suspects i think if this is an internal problem.... check oil filter assembly thoroughly and any oil cooler lines (if any) be sure oil level is up to be sure that is not why no iol pressure... does top end of motor rattle and clatter when running once warm or?
Will check. Wish the weather would stay warm as I am working outdoors. :(
more info... can't get oil pressure. when the engine warms up pressure disappears. Think the lines could affect that?
