How to set time zone on krippl p-3 type139W atomic clock
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
  • 13 Answers
SOURCE: Changing Time Zone on Wind & Weather Atomic Clock
1. Press MODE to select the time with the day of week
display mode.
2. Select the time zone by pressing and holding the “ + ”
button for 3 seconds.
3. Keep holding until the desired time zone (Pacifi c,
Mountain, Central, or Eastern) is selected on the
display map
Posted on Mar 08, 2009
SOURCE: can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
Posted on May 21, 2009
  • 3 Answers
SOURCE: Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Posted on Dec 21, 2009
SOURCE: Need instruction for setting clock model # 38229-1
Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
Posted on Mar 14, 2010
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    Sentry self setting atomic clock lost the instructions
    Select The Time Zone - For Sentry Self-setting Atomic Clock (ATC - 10)
    The default time zone is Pacific zone.
    1. In the normal time mode, press the MODE key to enter the alarm time mode.
    2. Press the SET key to change the time zone.
    each press of the SET key will move the time zone back one hour
    P= Pacific M=Mountain C=Central E=Eastern
    3. Press MODE key when correct Time Zone is highlighted.
    I think the Instructions may tell you to use the ADJUST key instead of the SET key.
    ADJUST key does not work for TIME ZONE change, SET key works.
    This will set your clock to your chosen Time Zone for normal time.
    Instructions for the ATC20 are located at the following url
    http://www.sentryindustries.com/pdf/instructions/ATC20_instructions.pdf
    Sep 28, 2010 | Office Equipment & Supplies
    How do I change the time zone on my skyscan atomic clock 3N6 VOO U?
    If you press and hold the set button on the back for 3 seconds you should be able to cycle through more settings, one of which should be the time zone.
    Hope this helps
    Sep 04, 2010 | SkyScan 86709 Atomic Wall Clock
    Mt atomic clock is always 2 hours slow no matter
    How to Change the Time Zone
    Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
    Sep 26, 2009 | Acu-Rite Adagio Clock Radio
    Can't figure out how to set the time zone
    May 18, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
    display mode.
    display map
    Jan 20, 2009 | SkyScan 86742 Digital Atomic Wall Clock
    Cannot properly reset skyscan atomic clock
    press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
    thanking you.
    Nov 19, 2008 | SkyScan 86709 Atomic Wall Clock
    Resetting the atomic clock to the correct time zone, and outside temp to work.
    For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
    For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
    Good luck,
    Doc
    Dec 01, 2007 | Baby Gear
    65 people viewed this question
     Grubhead
    Grubhead
