Question about HP iPAQ HX4700 Pocket PC
HX4700 will not power up
My HX4700 will not power up. It will also not charge when the unit is on the cradle. When I did a warm and cold reset it would come up to to HP screen but would go no further. I have 3 cradles and tried the machine in every one. The unit does not blink charge when it is put on the cradle nor will not power on. I bought a new battery and does the same thing. I have tried checking the battery clips to make sure they are tight. I have a separate charger for the bateries so I know the battery is fully charged. What could it be? Thanks
  • Brad Nebert May 29, 2007
    I tried the following fix on my Ipaq HX4700 and it worked. Reflashing the rom woke up my dead ipaq. The computer will be able to sync the ipaq when it is put in flash mode. My Ipaq would not read or sync with my computer unless I put it into flash mode. The rom flash is a bit tricky and it took me several attempts to get it to work but it is fixed. Worth a try on a dead Ipaq. see below
    How to Recover your iPAQ after a botched ROM Update
    If a user is attempting to update the BIOS or FIRMWARE of their iPAQ and the power goes out, or they accidentally turn-off their iPAQ, when then attempt to restart the iPAQ, it will only get to a white-screen, where it then sits forever.
    Bboth soft and hard-resets do not appear to clear the trouble in most cases.
    Hopefully you will never need to use this step-by-step process.
    I have confirmed with Nathan at HP Technical Support that this is their approved recovery process:
    1.) Go to the Master Index of BIOS, FIRMWARE, & DRIVER Updates,
    2.) Select the appropriate hyperlink for your model.
    3.) Download the most recent BIOS version SoftPAQ (SP) for your Model of iPAQ.
    4.) Press the POWER + iTASK + CONTACTS + RESET buttons at the same time so as to enter the FLASH Mode
    5.) Make sure your USB connection to the Cradle is hooked-up.
    6.) Place your iPAQ in the USB Cradle.
    7.) Stop the MS ActiveSync session on your HOST PC: CTRL-ALT-DELETE > TASK MANAGER > PROCESSES.
    8.) Hilight WESCOMM.EXE and select "End Process" button.
    9.) Run the file you downloaded from HP in step 3.
    10.) The iPAQ should now begin Flashing the iPAQ's ROM BIOS.
    This should work for most every iPAQ model, however, we cannot guarantee this will succeed at restoring your iPAQ to a usable state.
  • rizwaan_haya Aug 30, 2008
    i am facing the same problem
I have repaired many of the Hx4700s that appear to be dead by shorting across the "battery locked" switch. It is located on the lower right corner of the board when viewed from the back with the cover off. The switch just shorts to ground when the battery is locked in place. By flowing a small bit of solder over the two connections on the back of the switch, the iPAQ will return to life and there is no ill effect of bypassing this switch. In my opinion the switch is to fragile and poorly placed.
Posted on Oct 03, 2007
May be obvouse, but have you confirmed that the batery is locked into position. my prob is that the switch where that batter lock slider pushes into pooped out, and i need to replace. ugh.
Posted on Jun 20, 2007
Hi I'm a pc repair technician, and my ipaq hx4700 has gone exactly the same way. I've been looking round for some kind of technical manual to see if there is any history of internal components going down through heavy use or even manual abuse. Mine stopped after I knocked it whilst working on something. Normally if I see similar symptoms on a pc I'd be looking at internal component failure, more often than not the motherboard itself. I worked on that theory and have looked at prices for an ipaq motherboard. In all honesty the costs for the part and replacement are more than buying a new pda. Sorry for the bad news, but thats the only option I've found all the best
Posted on May 28, 2007
SOURCE:
Cannot get past opening screen or turn off unit. Unit seems frozen
Did you try to flash the BIOS/firmware of your device?
2.) Select the appropriate hyperlink for your model. (in your case it's here http://mobilitytoday.com/forum/showthread.php?t=4846)
Jan 11, 2008 | HP iPAQ HX4700 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
Hx4700 Dead
Try reflashing the rom:
Aug 17, 2008 | HP iPAQ HX4700 Pocket PC
Cannot power on...
How to correct iPAQ 5450, 5455, 5550, 5555 battery charging problems / dead unit syndrome.
The iPAQ 54xx or 55xx will not power on if the batteries charge is lower than 3.2 Volts, if your battery charge falls below the 3.2 volts level your unit will not turn on, you need to plug the iPAQ into a cradle or AC charge adaptor. Note the charging light on the iPAQ will not flash at all (normally flashes orange) until the battery charge has reached a minimum charge level of 3.2 volts. You then need to perform a normal reset, then the unit should switch on normally.
HP Procedure is as follows:
To charge and reset the iPAQ Pocket PC h5400:
i) Connect the iPAQ Pocket PC h5400 to an A/C power supply.
ii) Charge the battery to the minimum level of 3.2 Volts. This will take 5 to 30 minutes depending on the current charge level.
iii) Perform a normal reset.
iv) Power on the iPAQ Pocket PC h5400
It is recommended that you keep the iPAQ Pocket PC connected to the Universal Cradle or Cable when it is not in use.
Apr 30, 2007 | HP iPAQ HX4700 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
AC charging issue
Sounds like a defective AC adapter.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Battery too cold
Was it stored in a place that has extreme temperatures? If so, some hardware might have become damaged. Try to let the battery warm up some and then try again. I would also try a hard reset if at all possible and if that still doesn't work probably call up HP and see about a repair.
Sep 08, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
1,476 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
