Question about Acme 5001 Supreme Juicerator Juice Extractor
Excessive vibration and movement of  acme 6001 juicer during use. Tried different products, using less, not helpful.
    Problem Solver:
  • 5 Answers
Test by running empty for several minutes,, should be smooth running. then feed the juicer slowly. I have not seen a problem with what I feed in, solid or pulpy material not leafy material.
Posted on Apr 09, 2009
I bought a used Acme Juicer 6001 and when it starts working it's ok, but after 1 or 2 minutes, it starts vibrating and goes like crazy. I only put shopped vegetables, like cucumbers, apples, celery, and...
Just the opposite. The only way I get by the vibration is with an old worn blade which
I sharpen with a drill using a small bit. Installed a new blade, once, and the juicer took
off on me. Even the pro's have trouble with the vibration issue. If trouble persists, try
a pulp ejecting type.
Apr 22, 2011 | Acme 6001 Juice Extractor
Need instructions on how to use the Acme 6001 Juicerator.
Call Waring at 1800 492 7464, they may be able to help you out. There is not
a whole lot involved here. Place the juice bowl on the base first, then the basket,
blade, secure with the clutch nut and rotate the cover to lock it in place. Watch
out they vibrate, so juice hard produce evenly and slowly.
Oct 02, 2010 | Acme 6001 Juice Extractor
I am looking for parts for the Acme 6001 Juice
Just google Acme juicer parts. The new lids are a tight fit and
have to be filed down if you're handy.
May 11, 2010 | Acme 6001 Juice Extractor
My Acme supreme juicerator #6001 trips off several times before I can complete the process of juicing in order to get an 8oz. glass of juice. The motor spins smoothly, no vibration at all.
There is a reset button on the bottom of the
juicer. You will have to separate the base
by removing the 4 bottom screws and adjust
the sensitivity of the reset button turning the
small screw on it. Sorry, but forgot which
direction increases or decreases this. Had
to do it on my 21 year old Acme because of
the same problem.
Apr 22, 2010 | Acme 6001 Juice Extractor
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
Juicer works fine until slight pulp build up in
Unfortunately, since these juicers do not eject the pulp, they will tend to go out
of balance. Juice nothing softer than apples and try to feed it as evenly and as
slowly as possible.
Nov 27, 2009 | Acme 6001 Juice Extractor
The 6001 vabrated so much the top came off and the flang bent.
WARING AT 800 492 7464 HANDLES ACME
JUICERS. VIBRATION MAY NOT INDICATE
REPAIR. THIS JUICER DOES NOT EJECT
PULP SO IS PRONE TO VIBRATION JUST
LIKE AN INCORRECTLY LOADED WASHING
MACHINE. HOWEVER, SEVERE VIBRATION
WILL CAUSE THE BLADE TO CHEW UP THE
CHUTE. YOU WILL NEED A NEW COVER.
TALK TO WARING. ANOTHER PROBLEM
IS NEW COVER PROVIDED WILL NOT FIT
SOME OLDER JUICERS WITHOUT FILING
DOWN THE EDGE OF THE COVER. TAKES
TIME BUT CAN BE DONE.
Jun 24, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme 6001 juicer. Excessive vibration and movement during use.
usually the vibrations are caused by improper assembly ( it does not take much ) or the rate of feeding material into juicer. feed the juicer too fast and it gets out of balance.
Jan 04, 2009 | Acme 5001 Supreme Juicerator Juice...
Acme 5001 Supreme Juicerator Juice Extractor Logo
198 people viewed this question
Top Acme Juicers Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you an Acme Juicer Expert? Answer questions, earn points and help others
