Question about ASUS PW201 LCD Monitor
Monitor doesn't switch on
Nokia 5130 switch on problem
remove switch.
and short switch point to ( - - ) & ( + + )
u can on your cell without switch
Jun 23, 2013 | Nokia 5130 Cellular Phone
L19wa monitor
It could be your sound cable is detached. it could be the inbuilt amplifier has failed.
Apr 24, 2013 | Computers & Internet
My Insignia Monitor doesn't work with my laptop, I've tried everything, from pc settings to cables, etc, i only receive a NO SIGNAL ad
Usually you have to toggle the display output on the laptop. The FN key + one of the F# keys with a monitor icon on it. Toggle it until it outputs to the monitor. Your getting "no signal" because no signal is being sent to the monitor or you have the monitor on the wrong input if it has multiple inputs.
Dec 24, 2012 | Insignia Computers & Internet
No power at all
If your monitor doesn't turn on, and you are sure of the power supply (some plug directly into the wall and some use a power adapter), then you can assume that the monitor has failed.
You can fix it (replace the power supply in the monitor itself or possibly the on/off switch), have it fixed by someone who knows how to do this, or buy a new monitor.
First, of course, be sure the problem is your monitor and not the computer. If the monitor light turns green and then yellow, you can assume it's the computer. If the monitor light doesn't go on at all, it's the monitor.
Nov 18, 2011 | Computers & Internet
I bought a LG Flatron E2240 Monitor & added a new graphics card & it keeps freezing the arrow doesn't move
sir i think it'll be nice if u remove the new graphics card from the PCI slot ... then it''ll play in the normal default graphics now u uninstall the software driver of ur graphic card then insert back it again and once again install the software with care... all will be fine ... there is no problem with the monitor sir ...:)
Sep 04, 2011 | Computers & Internet
My monitor doesn't have an adapter. It says 12 vDC but I don't know the amperes or mA it requires, What do I do?
moz-screenshot-7.pngHi
The supply would be 12v DC 1000mA you can even go little more in amperes like 1500mA also not a problem.
DO RATE MY SOLUTION
Jun 30, 2011 | Daewoo F227B Monitor
Hi. the mobicam keeps turning on and off and the light is flashing?
What does the VOX switch do?
When the VOX function is active, both the LCD screen & Audio turn off and will automatically reactivate when there is
noise in the room being monitored (e.g. baby crying). This feature is useful at night so the light coming from the screen
doesn't bother you and also when running the MobiCam Ultra receiver on batteries since it will extend the life of the
batteries. Note: The VOX function will not work when batteries are low and you cannot change channels on the receiver in
the VOX mode
Jun 14, 2011 | Mobi-Cam Mobi AV Monitor
I have a Trulink VGA 4 port KVM switch. Has worked fine for a year plus. Just moved it to a new room, and reconnected the same computers to the switch using a new monitor. I can't get the monitor to work....
Maybe the switch doesn't support the type of monitor that you are trying to use. Have you tried switching back to the old monitor to see if that one still works?
May 04, 2011 | Computers & Internet
I just got a used 2 port KVMDVI switch to run my PC and PS3 simultaneously. The PC view is working fine but when I switch to the PS3 I get a black & brown screen. (I know it is getting a signal because...
The SC switch is a Secure Switch for Goverment applications and or Military Ops, PS3 is therefore not a supported target. First of all because the Interface is most like HDMI owhich your switch doesn't support, the usage of adaptors are not going to work on that kind of switches.
I hope that helps.
Jan 15, 2011 | Avocent SwitchView 10040-SC 4-port KVM...
ASUS PW201 LCD Monitor Logo
37 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
