Question about Frigidaire FGR341AC Electric Dryer
Very very hot
I have a frigidaire electric dryer , when in use the back side top gets so hot the paint is starting to char and the top get very very hot . any clues to why this is happening
  • 56 Answers
I would say the heat senser is not oicking up the right temp. you should have a tec. check it out and not run it until they look at it a dryer can catch fire quickly. please be safe.........
Posted on Jan 05, 2009
I have a frigidaire front load dryer that has the round frond door and control panel on the top frontof the cabinet. how do i open the case and replace the blower fan blades?
If the top LOOKS like it can open or come off, look all around for any screws that may hold it in place. Then, using a thin, flat, flexible putty knife find the catch release tabs, usually in front, one on each side about 3-4 inches in from right and left front corner. Press these in while applying some upward pressure, use a wooden paint stirrer to apply opening pressure without scratching the paint! If this does not work, DO NOT resort to the Milwaukee Sawzall with a metal blade! The metal shavings will get stuck in your clothing and be very uncomfortable. Good luck!
May 06, 2011 | Frigidaire Electric Dryer
I have checked and cleaned the vent hose and screen. However the back of the dryer gets very hot. Also the top gets to hot to even place your hand on it Frigidare GLER341As2
There is a safety thermo switch that is located on the top rear by the controls, it may be going bad, as if the coils get to hot it is suppose to shut the dryer down.
Jul 24, 2010 | Frigidaire GLER341A Electric Dryer
How do I get the back panel off, so that I can get to the fuses? The screws have been removed. It appears the back panel is either glued,welded or painted shut! My dryer is spining but there is no heat?
Put all the screws back in the dryer where they go. The heater has probably dropped down and will be fun to resecure but it must be done. All service to your dryer is done through the front and you don't have to move dryer from wall at all. Use a flat bade scre driver or putty knife on the front left and right sides at top and the top pops up and there are the t-stats and all.
Jun 02, 2010 | Frigidaire FER641FS Electric Dryer
Electric Dryer run too hot
wow, dont get burned, check your ventillation, make sure your vent is not clogged or smashed, if this continues, then change out your thermastat
Aug 16, 2009 | Frigidaire FDE647RF Dryer
May dryer is not getting hot
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Charred wire connectors
Hi, You will be ok. This usually happens in time do to vibration. It is not a prob;em from the dryer acting up.
I hope this helps you.
Vic
Jun 19, 2009 | Dryers
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Frigidaire FGR341AC Electric Dryer Logo
273 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
