Question about Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET
I have a utilitech jet pump in which i have to turn off the power switch and wait ten minute, then turn it back on so it could run the water.
    Sergeant:
  • 293 Answers
An electrical fault is tripping off the power relay. Check the current draw of the pump motor.
Posted on Nov 06, 2012
  • Karen Robinson
    Karen Robinson Jun 03, 2014
    I think the answer to your problem is to not buy a Utilitec pump. This is my third pump in 4 years, and it will be my last one. There has to be a better pump than this.
I have a UtiliTech 1/2 HP Jet pump #0003124. I need a manual. Can I get a larger volume impeler for this mode?l
Put a vacuum gauge on the suction, see if it goes real low after pumping a couple of gallons. If so, your point may be stopped up. A 1/2 hp pump should pump 40/50 psi, fill a 5 gal bucket in a minute or so.
Jul 29, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Where do the wire leads connect to the switch?
Look on the id plate on the motor, and inside the cover on the back and inside the switch cover.
Jul 03, 2015 | Utilitech 1/2 HP Convertible Jet Pump...
Why does the pump lose pressure? there are no visible leaks, of water or air
for the pump to lose pressure there has to be a leak somewhere please check and make sure you have a one way valve on the bottom of your jet pump that will not allow the water to run back into the well
Nov 29, 2014 | Utilitech 1/2-HP 9-GPM Shallow Well Jet...
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Once the water is shut off the pump keeps running
the pump is controlled by the storage tanks pressure switch , if it continues to run well after the pressure tank has refilled with water , either the switches manual override has been activated (lever) or its defective or blocked off with mud
Jun 27, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Cracked water pump
You should be able to replace the housing if you contact the manufacturer.
Mar 12, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground lines....
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Bud
Oct 21, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET Logo
665 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
jhnolson
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
