Question about Kitchen Appliances - Others
Foodsaver vac 350 will not seal a bag - Kitchen Appliances - Others
  • 11 Answers
SOURCE: Tillia Foodsaver VAC 370 won't stop vaccuming to seal
My Foodsaver 820 wouldn't stop vacuuming, and after fiddling with it and doing a little research, I located the vacuum switch on the circuit board and de-soldered it (verry simple, only 2 solder points). On the underside of the switch it looks kind of like an allen head screw. NOTE before attempting this, make note of how far the screw is recessed into the housing and/or count how may turns it takes to remove it! I removed the screw and spring and sprayed electrical contact cleaner in the holes and in the hole where there is a little brass disc. (Wear safety goggles for this) The little brass disc is what makes the contacts that turn the pump off after reaching the necessary vacuum. Mine was gummed up and stuck so it would never make contact to shut off. I reassembled it, and re-soldered it back on the board. I then put the whole thing back together and it works like new.
You could probably make the same repair without removing the piece from the board since there is a hole in the circuit board where you can gain access to the screw, but it will be messy. If you have any experience with soldering, it is about as simple as it gets
Posted on Jun 25, 2009
SOURCE: My Foodsaver Vac 1050 doesn't extract all of the air from the bag
Either the sealing strips are dirty letting air escape or the lips of the bag are turned upwards. Push the front of the bag down towards the bottm chanel and it should work fine. I have had one for eight years now and love it.Ken Vancouver BC
Posted on Nov 21, 2009
  • 88 Answers
SOURCE: My foodsaver Vac 420 Vacuum Sealer won't heat and
This is likely happening because the unit cannot detect that a vacuum has formed, and because of this, the unit will not seal the bags, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
heatman101
  • 43501 Answers
SOURCE: foodsaver vac800 not sealing bags any way to fix
No, the heating strip is actually a wire that get s warm the do the sealing...when the wire breaks there is no more heating and there is no way to repair that wire...
heatman101
Posted on Sep 16, 2010
Testimonial: "20 mins. got my answer fast thanks"
  • 731 Answers
SOURCE: foodsaver V845 is not sealing?
Does the vacuum seem to run forever and it doesn't seal?
Clean the black foam seals
Replace them if needed. they can be purchased from Tilia
WWW.FOODSAVER.COM
Posted on Jan 24, 2011
Foodsaver V3835 seals but will not sufficiently vacuum.
Go on the Foodsaver website to get replacement foam rubber seals that contact the bag during the vacuum process.
Feb 17, 2017 | FoodSaver Kitchen Appliances - Others
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
No suction to seal bag
is a hose unplugged? Unplug the devise and see if you can find anything that looks like it's not connected OR it has a hole in the hose.
Sep 07, 2012 | FoodSaver Vac 800 Vacuum-Sealing Kit,...
I need a owner's manual foodsaver compact fc-no-202412 i dont no how lang to l hold it down to seal the bag.model foodsaver compact .f.l.a.e.m.nuova.s.r.l
Well you many please follow the below link to get your manual -
http://www.foodsaver.com/manuals/FoodSaver/T000-32030_English.pdf
Check out page number 4 on this manual to know the time to seal the bag.
Good Luck!!
Thanks for using FixYa!!
Aug 28, 2010 | Tilia FoodSaver V2240
My foodsaver Vac 420 Vacuum Sealer won't heat and seal the bags.
Dolphin Dive Center
Mar 29, 2010 | Tilia FoodSaver VAC420
V3460: no response when pressing seal and inserting bag. What should I do? Thanks
  • Assuming that the unit is plugged in and the plastic bag is in the proper position.........
  • Press firmly and equally on both sides of the cover (where the three raised ridges are on each side). The 2 micro switches that start the vacuum motor are located there and require firm pressure to operate properly.
Jan 20, 2010 | Tilia Foodsaver V835 Vacuum Sealer
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
the function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Jul 13, 2009 | Tilia FoodSaver V2240
Dec 30, 2008 | Tilia FoodSaver VAC420
Kitchen Appliances - Others Logo
750 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
