Question about Toshiba Computers & Internet
Toshiba satellite laptop-a205-s5000 cd/dvd player doesn't work need help
My cd/dvd doesn't work;I downloaded a software and it fixed it.I had to go back and a restore on my laptop and it took the download off. now it doesn't work again.I don't know which site I downloaded it from. I need help fixing the cd/dvd again thank you
  • Toshiba Master
  • 7,627 Answers
Go to the Toshiba Website look for original drivers for the device.
Posted on Nov 04, 2012
  • 9 Answers
SOURCE: Toshiba Satellite A205-SS5000's dvd drive
A virus can cause that problem but it could be as simple as the drive going bad. I would formatt & do a clean OS install. That would rule out a virus problem.
Posted on Dec 31, 2008
SOURCE: Restore Original Configuration
If you have not yet found time to call Toshiba and get the recovery CD you may try the following:
1. Reboot you system
2. Press F1 (immediately you get options to press F2 and F12)
3. Press F8 (this will give you more options including system recovery)
Please ignore if you already have the CD. Having the CD is the best as previously said.
The step above have helped me many times to avoid doing factory system restore. I hope it helps you or someone else.
Posted on Jun 12, 2009
  • 25 Answers
SOURCE: TOSHIBA SATELLITE A205-S5000 WORKED THIS MORNING,
It sounds like the battery is done...happens a lot. You may be able to just by a new battery pack to solve the problem.
Posted on Oct 06, 2009
  • 1752 Answers
SOURCE: i have toshiba satellite A135- with vista
Contact Toshiba, they'll sell you one.
Posted on Nov 01, 2009
  • 368 Answers
SOURCE: HOW CAN I RESTORE TOSHIBA SATELLITE A205-S5804, I
I am glad to HELP YOU!
You will need to use RESTORE PARTITION [existing on your hard drive] or the RECOVERY DISKS.
Some details you have HERE.
GOOD LUCK!
... and don't forget to RATE, please...
Posted on Apr 26, 2011
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Satellite A205 Toshiba The DVD is not recognized by the computer
If the computer is seeing the drive try to re-install drivers first. If re-installing the drivers doesn't work your may need to replace the DVD drive.
Jul 16, 2012 | Toshiba Satellite A205-S5879 Laptop
How do you restore facotry settings on a toshiba satellite a205-s5000
create recovery disk with satellite recovery media creator in your satellite laptop, then boot up your laptop with cd recovery you create and you can start recover to factory default setting
Mar 10, 2012 | Toshiba Computers & Internet
How do you restore a toshiba satellite to facotry settings
A205-S5825...Vista Home Premium Message comes up "no DVD" when trying to play movie on WMediaCenter. Does not show "Play button" on Toshiba DVD Player. After looking through...
Hiya..just my opinion..forget media centre, download VLC player..It will ask if you want it as your default media plater..Say Yes (it plays all formats) if that doesn`t solve the missing DVD player, update your drivers from the Toshiba site. Failing THAT..
Google " CD/DVD run repair" I have had the same problem and there are a few free programs to fix problems.
Just ideas of the top of my head . good luck Pete
peter.b@aussiebroadband.com.au
Oct 13, 2017 | Toshiba Satellite A205-S5812 Notebook
Toshiba a205-s5000 forgot dmin9strators password. dpn't want to loose data help
Go to the link below and download the cd/iso file of KonBoot. Make a cd and boot from it on your locked puter. It breaks any windows password and you can reset.
http://www.darknet.org.uk/2009/06/kon-boot-reset-windows-linux-passwords/
Cya
Marcus
Sep 17, 2010 | Toshiba Satellite A205-S4617 Notebook
Ihave Toshiba A205 S5880, can not play DVD I
There is problem on your DVD or software which u have install that does not support the file.Most probably VLC is the only media player which can give large support for media files.Please download and install vlc media player.
Aug 21, 2010 | Toshiba Satellite A205-S5880 Notebook
A205 s5000 motherboard. Where can i get one?
Google is your friend
http://www.sparepartswarehouse.com/Toshiba,Satellite,A205,Laptop,System-Boards.aspx
Sep 17, 2009 | Toshiba Satellite A205-S4617 Notebook
On my Toshiba Satellite a205-s4707 dvd player not working
Allright this one can be tricky so we need to isolate the problem between software and hardware.
First, get into the bios and see it's being detected.
If not then turn off the computer and unscrew the drive from the laptop, MAJORITY of laptops only need to have one screw unscrewed to release the drive. If yours doesn't then you'll have to do a little more work, let's just assume you have the majority for now.
Next, pull the drive out, feel free to give the back connector a quick puff of air, now carefully place the drive back into the laptop so that it's nice and tight.
Check to see if that solves your problem.
If not we'll try something else.
Feb 22, 2009 | Toshiba Satellite A205-S4707 Notebook
Computers & Internet Logo
93 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
