Question about Electrolux EI30BM55H Microwave Oven
How do you replace the door handle on a Electrolux Microwave door model E130BM55HSB?
  • Official Brand Answer
  • 4,342 Answers
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Since this is a complex unit, typically this is something that you want a certified professional to install for you to prevent any exposure to radiation, safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process
Posted on Nov 08, 2012
Model E130BM55HSC. How can I replace lower door handle bracket?
Hello Teresa, thank you for your inquiry!
I understand that you need assistance replacing a component on your Electrolux microwave. In order to replace the bracket you would need to disassemble the door. You should seek help from a professional technician for proper assistance with the disassembly. This will help you avoid any personal harm of improper disassembly of the microwave. Best of luck! -Matt
Mar 09, 2016 | Electrolux Microwave Ovens
Are the doors from electrolux eml38405x microwave oven can fit to electrolux emc38905x?
Replacing the door is one of the most demanding service interventions in the microwave. Substitution is possible only with the original door, otherwise may cause leakage of radiation what is very dangerous.
For identity doors of two different models of the microwave please contact an authorized service center.
Dado
Apr 11, 2015 | Electrolux Microwave Ovens
Have loose handle on electrolux icon microwave. How to repair.
There is screws inside the door when you openi it so you tight them thats all
Sep 15, 2014 | Electrolux ICON Microwave Combination Oven
Replacing relay switch in electrolux high speed microwave oven
Sometimes a door latch or magnet closure is a problem. If the door fails to make proper contact when closed, the oven will not start. If the oven goes on and off, there is a disconnect and in some cases the rotating glass dish inside vibrates and causes a disconnect also.
Dec 18, 2013 | Electrolux ICON Microwave Combination Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
E30so75fps loose handle
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
Jun 06, 2012 | Electrolux ICON Microwave Combination Oven
How to fix loose handle on Electrolux TINSEB4225MRRO
you must open the door in two parts, for that unsrew the screw from the door sides, remoove carfuly the isolation and screw the handle.
Feb 20, 2010 | Electrolux ICON Microwave Combination Oven
The door handle broke off my GE microwave
Actually the door handle CAN be replaced at a cost much less than pruchasing an entire new microwave oven. And, YOU can repair this yourself and save the cost of a service call. On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
If the model number is correct, the part number is WB15X322. The cost is about $40. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you
Dec 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Electrolux EI30BM55H Microwave Oven Logo
57 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
