Question about Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by
Remove moen monticello handle hub - Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
  • 19 Answers
SOURCE: how to remove the handle of a monticello 4551 moen
grab bottom of handle,(the fat part of handle closes to faucet body) and grip hard and turn counter clockwise to get to cartridge. dont use channel locks pliers or you risk damage to finish. can be done by hand and very tight grip
Posted on Jul 07, 2009
  • 30 Answers
SOURCE: My Monticello has a loose handle.
If you click on the "Illustrated Parts Diagram" link in the link attached, you will see in the link below how you just need to twist the elbow in order to tighten it onto the hub.
Posted on Sep 22, 2009
  • 129 Answers
SOURCE: need to replace handle adapter kit on a Moen
Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
Posted on Sep 29, 2009
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    How do I replace handle adapter kit for Monticello?
    Unthread the handle hub (ccw), once detached, turn the handle upside down. There is a Phillips screw inside that once loosened (ccw) will allow you to replace the adapt.
    Feb 18, 2015 | Moen Bathroom Sink Faucet - 4-inch...
    7700 series Moen leaks at top and bottom of base hub
    You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
    http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
    The replacement o-ring and retainer parts were free to me. Hope it helps you.
    Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
    Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
    Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
    Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
    Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
    You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
    You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
    You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
    I hope this helps.
    Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen monticello shower control, remove handle
    If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
    Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    Sep 20, 2009 | Moen Bathroom Sink Faucet - 4-inch...
    Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by Logo
    60 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
